03-22-2020, 02:49 AM | #1 |
Windshield frame repair panel
Does anyone know if new windshield frame repair panels exist and if so where I could get one? I have searched google but can't find anything.
The frame behind where the windshield rubber sits is rotten (only along the bottom edge) so I guess I am going to have to cut and bend some repair patches from sheet metal. If a repair panel exists that would save me a lot of time. Thanks |
03-22-2020, 10:56 AM | #2 |
Re: Windshield frame repair panel
I ran into a similar problem, and had to go to the jy to cut out what I needed.
03-22-2020, 11:45 AM | #3 | |
I agree batt ripe saw junk yard cut all the way throw the double metal bends.
No there is no panel in that area you have to do like said.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
