06-19-2019, 10:17 AM | #1 |
funny fuel problem,need suggestions
80 chev truck stock 350/350 with headers ,performer intake and 4106 edelbrock carb. Everything new in the last 5 yrs. It,s starting to get warm here 32 degrees Celsius about 90 F. Here,s what happens, start truck in the morning,let it warm up abit and go and a minute or 2 of driving it runs out gas . Sometimes you can catch it and pump the gas while driving if not I put in neutral and start it right up no problems, no pumping just click vroom . Then it,s fine all day. It seems to do it from warming up to before full operating temp. After that is fine. Did this a couple tears ago for abit . It doesn,t do it every day but when all the conditions are right it does it but what conditions I don,t know. I,m thinking some sorta vapor lock or low idle mix, gas cap ? Single line to gas tank if that means anything
06-19-2019, 10:21 AM | #2 |
Re: funny fuel problem,need suggestions
I'm certainly no expert, but I see no mention of a carb spacer. I might suggest getting one of those phenolic carb spacers and install it, potentially eliminating the heating of the carb/fuel. Have you checked the fuel pressure? It's been mentioned many times that Edelbrocks don't like a lot of it, maybe 5-6 psi. The single line shouldn't matter much. That's how my truck was plumbed too.
06-19-2019, 10:57 AM | #3 |
I don,t see why I need a carb spacer, It does this before operating temp. It does have a thicker gasket with some sorta heat transfer ability
06-19-2019, 11:27 AM | #4 |
Automatic choke ???
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
06-19-2019, 12:31 PM | #5 |
Just a cold intake.
At the right low morning temp near 10C and higher humidity(moist air) the result is fuel puddling in the intake. The fuel vapor cools when in contact with the plenum and reverts back to a liquid state. Your motor runs lean and quits. When you start it back up there’s enough air/fuel vapor flow to keep it running and usually clean out the excess fuel in the plenum. Next time it does it make note of the temp and humidity. |
06-19-2019, 08:56 PM | #6 |
Geezer, Makes sense .I remember my dads dodge truck from the 80,s and was a 318 and if rained at night it was hard to keep running for the first 15 or so minutes in the morning. Anyway was cooler this morning and no problems . Seems to be the opposite ,warm nights , temp didn,t drop below 14. C those nights and that,s when it acted up. Wonder if the gas tank might be creating some vapor at night on high night time temps. Gas tank is never full ,maybe half at the most.
06-19-2019, 08:57 PM | #7 |
06-20-2019, 11:03 AM | #8 |
It was just a suggestion is all. My Edelbrock ran a little bit better after I installed one. It's better insulation than just a gasket.
06-20-2019, 09:00 PM | #9 |
Thanks , I hope my message didn,t sound bad. I have used them before on other engines but I don,t think I need one in this case. I really don,t like this Eddy carb to be honest. Buy the carb ,but oh, you need this and this to make it work.$$$$.
06-20-2019, 10:29 PM | #10 |
Well, it just sounds like your engine is having trouble with the transition between running cold and running warm/normal.
06-20-2019, 10:37 PM | #11 |
Moderator
If you have a working Delco THERMAC (thermostatic air cleaner system) on the air horn, with the damper pipe connected to a stove around the exhaust manifold, it tends to alleviate the intake icing somewhat.
It really gets exciting if the throttle butterflys ice up.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-21-2019, 09:12 AM | #12 |
06-21-2019, 10:30 AM | #13 |
06-21-2019, 02:54 PM | #14 |
Mine did the same thing except around 40~60*F and high humidity. Fixed it when I replaced the temp sensor in the THERMAC system that had failed open. It already had the carb spacer on a performer manifold with 1405 eddy carb.
