Old 01-21-2019, 03:07 PM   #151
big_moss
big_moss's Avatar
Re: 51 chevy 3100 5 window build
Some recent progress
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 01-21-2019, 06:19 PM   #152
FAKKY
For the axle flips for lowering and ride quality I've seen some comments where people say use a bolt in rather than a weld in.
Personally seems like we weld so much on altering these trucks that it shouldn't be an issue ..... but makes me wonder why the bolt in kits etc ?
http://djmsuspension.com/flip-kits/
"Resist the temptation to weld these plates in. Your frame is probably tempered which means you can weaken it by applying heat. It’s a little more work to drill the holes but a lot safer."
Is it that our frames are not tempered steel ?
Never quite understood it exactly --- I know when I owned my diesel guys on that forum would freak out if you mentioned welding on frame.
nice looking truck.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 01-22-2019, 10:25 AM   #153
99 to Life
99 to Life's Avatar
looking good moss.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-09-2019, 12:27 AM   #154
big_moss
big_moss's Avatar
Body is off getting sand blasted. Should be done this weekend weather pending we had some tornadoes in our area this past weekend so kinda put a damper on things. Gonna ha e my spot at the metal work shop on the next month or so. So possibly going to have the motor and trans built on the mean time.
Old 04-09-2019, 12:38 AM   #155
99 to Life
99 to Life's Avatar
yah moss. that was a nice patina. what is your color scheme gonna be?
Old 04-10-2019, 09:40 AM   #156
big_moss
big_moss's Avatar
This is the blue I want to do
Old 04-10-2019, 09:55 AM   #157
99 to Life
99 to Life's Avatar
very nice. this is the blue I used for Geronimo
Old 04-10-2019, 10:00 AM   #158
big_moss
big_moss's Avatar
Yeah I'm taking the rear end to get built and hopefully the motor and trans all within the next week
Old 05-19-2019, 12:45 AM   #159
big_moss
big_moss's Avatar
Picking the body up tomorrow hopefully gonna be taking it to metal work very soon
Old 05-19-2019, 07:46 AM   #160
reaper71
reaper71's Avatar
What's the plan with metal work? I.E. custom touches,stock etc.
Mark
reaper71 is offline   Reply With Quote
Old 05-19-2019, 07:50 AM   #161
99 to Life
99 to Life's Avatar
Nice, did you blast that yourself? if so how long did that take and would you do it again without an enclosure?
Old 05-19-2019, 02:06 PM   #162
8man
Nice work. Like the build.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-29-2019, 09:50 AM   #163
big_moss
big_moss's Avatar
No I didn't blast it myself I had a buddy of mine get it done for me. Got it home this past Saturday and applied Gem rust killer in the entire body. Hopefully it's off to metal work soon. Trying to get a friend of mine lined out for a place he can do the work. Whole new roof panel, ls fab firewall, toe boards, and kick panels, whole new front and rear floor, rockets and cab corners, and new lower door skins.
Old 07-05-2019, 02:40 PM   #164
big_moss
big_moss's Avatar
whats up guys well got a few things buttoned up on the chassis finally got my metalwork/body work and paint all lined out and it should be going to the shop within the next 2 weeks. already got the trans built for 600 hp with a 3200 stall so its ready to go. the block that i had was no good was already bore 60 over and im building a 383 so it wouldn't have worked already have another block at the machine shop and it should be getting close to being done. still pushing to have the truck done for my car show in November
Old 07-18-2019, 05:22 PM   #165
big_moss
big_moss's Avatar
hey guys whats up ive got some updates the truck is getting dropped off for metal work and paint and body Saturday and finally get to clean my garage out of the 7,000 dollars in replacement panels i have for the truck. my motor guy called and said the crank pulley is at the balancing shop and assembly should start next week. looks like its all starting to come together
Old 07-18-2019, 10:18 PM   #166
99 to Life
99 to Life's Avatar
long process. nice to get it outta the shop sometimes. Cleaning up is a good feeling!
Old 07-19-2019, 09:06 AM   #167
big_moss
big_moss's Avatar
99 thats for sure man when it comes back all it will need is wiring plumbing and interior im very excited
Old 07-23-2019, 03:36 PM   #168
big_moss
big_moss's Avatar
can anyone help me with a tilt steering column, steering shaft/ knuckles needed , and a frame mounted hydro boost set up part numbers thanks in advance
Old 03-14-2020, 01:21 PM   #169
Tinbasher
Awesome truck man! Any progress?
Tinbasher is offline   Reply With Quote
