03-23-2017, 12:08 AM | #1 |
Question about electric fuel pump
I picked up a used engine off a 92 chevy 2500. I believe the cam does not have the lobe for a mechanical fuel pump so I'm going to wire up an electric one. I ordered a Carter pump since they seem to be the more reliable name. My question is that if I need to run a pressure regulator if the pump is rated at 4-6 psi? I'm running a 1406 edelbrock carb. Any advice is greatly appreciated.
03-23-2017, 04:11 AM | #2 |
Re: Question about electric fuel pump
I had an edelbrock carb on 68. Never could get to run right changed metering rods and springs several times. Ended up going back to a Holley. Not sure about your pressure question. The edelbrock FAQ that I seen says no more than 6.5 lbs though. Not sure if that helps you. Oh I forgot. I just found an unopened pair of rods the other day. No idea what size but if you want them I'll mail them to ya.
03-23-2017, 09:24 AM | #3 |
Edelbrock might say 6.5 psi but 5 psi is better.
Try your carter, if it floods put a fuel return style regulator on it. You'll need a return fuel line for that. THe reason for that type reg is electric pumps heat up and quit if they're deadheaded. |
03-23-2017, 12:12 PM | #4 | |
03-23-2017, 12:14 PM | #5 |
Thank you. I guess I'll try it and see what happens.
03-23-2017, 01:31 PM | #6 |
fellas.. I ran a '94 350 for about ten years in my '67. I removed the plate, put a pushrod in the hole, and installed the fuel pump. It pumped just fine, but your results may vary.
67 C-10 shortwide '06 Triumph Thruxton '09 Harley 'Lectra Glide '95 Z-71 two door Tahoe |
03-23-2017, 02:56 PM | #7 |
I've used the old Carter fuel pump (the click-click-click style) without a regulator in a few cars in my lifetime, so it should be good.
I did have one cook a battery in the hardest-to-diagnose problem I've ever had, but it's a long story and only applicable to long highway drives if you have a mechanical voltage regulator: when the battery is fully charged, the pump's electrical load cycles the regulator ON briefly but the pump's draw time is shorter than the regulator's response time, meaning the regulator is ON longer than it needs to be. Over a long drive that can overcharge and boil a battery. But that's not a reason to avoid the pump or anything!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-23-2017, 03:33 PM | #8 |
That was my plan but when I put a rod in and rotated the engine I didn't feel the lobe hit. The previous owner had installed a rv2 cam and I'm guessing it didn't have the lobe for the fuel pump.
