05-23-2019, 11:36 AM | #1 |
Where to plumb proportioning valve?
I converted to Hydroboost a few years ago, using all components from the same truck. Unfortunately, I can’t find my notes to tell you what year. I believe it was an ‘86 3/4 ton, but not positive. Also used lines from a 73-87 truck ran down to a combination valve. I have disk brakes on front (slid in a 73-87 full crossmember), and a 14 bolt rear with the big drum brakes.
Brakes work well, but the rear locks before the front, and I would like to install an adjustable proportioning valve. Should this be plumbed in after the combination valve? Also, I have Wilwood D52 calipers up front and would like to use a Wilwood prop valve, anyone have a recommended part number? |
05-23-2019, 11:51 AM | #2 |
Re: Where to plumb proportioning valve?
I’ve used one like this.
https://www.tmrcustoms.com/ca/brake-...hoCkdgQAvD_BwE Plumbed in within a few inches of the prop valve on the rear line works best. |
05-23-2019, 12:52 PM | #3 |
Thanks, geezer. So you mean plumb it in AFTER the combination valve on the rear brake line, correct? Not between the master cylinder and the combination valve on the rear brake line.
05-23-2019, 01:06 PM | #4 |
Yup!
After the combo valve on the rear line. |
05-24-2019, 10:41 AM | #5 |
Never Ending Projects
Agreed. After the combo valve.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
