Old 07-27-2017, 02:23 PM   #1
dmartin1
dmartin1's Avatar
67-72 Motor mount strength?
Im putting a 454, 10:1 compression, ported 049 heads, large cam, and some other goodies into my 71 k10.
Ive clearenced the firewall, and am modifying the oem crossmember to fit.
My concern is the oem style motor mounts. The pad with the bolt that bolts into the center.
Are new poly mounts in this style sufficient? Was looking at the energy suspension brand.
The diy4x competition poly mounts for 73-87 caught my eye too. Anyone use these on a 67-72 k10?
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 07-27-2017, 02:45 PM   #2
67 chevelle
67 chevelle's Avatar
Re: 67-72 Motor mount strength?
You should make serious power with 049s , I had one in a 72 chevelle ,,, 650 foot pounds gets your attention .. as long as you have the interlocking mounts you should be good , energy suspension are quality pieces , make sure you get the right ones some are 2 3/8s some are 2 5/8s , and im sure there are other variables
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-27-2017, 03:03 PM   #3
dmartin1
dmartin1's Avatar
The motor was actually out of a sunken v drive hot road boat.it was down at the bottom of our river about 30 minute.
They cleaned and reassembled everything and it fires right up.
Everything from the holley 750 dp to oil pan.
I got the entire engine for crazy cheap, scrap price.
Im just gonna run it, it has ran a while now on stand with great temps and oil pressure.
Thanks for the input on the mounts, i can always change later on too.
65 nova
And more
Old 07-27-2017, 10:07 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by firedemon View Post
didn't the factory have a cable or chain that connected the motor to the frame in case the mount broke . someone might chime in but I would definitely check it out with that much horse power
Yes they did. Cable.
LockDoc
Leon
Old 07-27-2017, 10:21 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
That cable set up was used for '65-'69 vehicles only, with the mechanical rod that actuated the carburetor. Once a cable set-up was used, starting in '70, there was no danger of the throttle being pulled wide open when the engine torqued up if a motor mount broke. Optionally, one could opt for interlocking motor mount installation. Most people who were out of warranty didn't do that, as the cable installation was free, as a safety recall retrofit, only.
~Steven
Simi Valley, CA
Old 07-28-2017, 12:09 AM   #6
PeterHall
Im installing the diy4x crossmember for your exact concern. We reused the stock crossmember but now we're building our 454 for more power and I was worried about pulling out that tiny little bolt out in the motor mount.
The stock motor mount did hold up to the boring crate 454.
PeterHall is offline   Reply With Quote
Old 07-28-2017, 01:19 PM   #7
BILT4ME
We are installing the "Torque Cables" on our 70 GMC K2500 as we install the new engine. I want it for pulling the tree stumps or what ever so the motor mounts don't actually break.
They look like these.
http://www.ebay.com/itm/GM-325874-19...53.m1438.l2649
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 07-29-2017, 07:28 AM   #8
Grumpy old man
Grumpy old man's Avatar
all the cable stay kits I've seen are for small blocks , I'd be more concerned about whats going to happen to your frame once you start turning loose 3 times what it was designed to handle ? Chevy twist is real .
