06-05-2017, 10:19 PM | #26 |
Re: Chopping the bed floor, making a rolled over rear edge
If anyone is wondering what it looks like with the extra cross brace at the rear, here it is.
And no, I haven't cut the frame yet.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 06-05-2017 at 10:30 PM. |
06-05-2017, 10:28 PM | #27 |
And the former 2nd cross brace at the front is already in the right position as the new first cross brace. It will just need to be drilled and a sleeve installed.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-06-2017, 08:35 AM | #28 |
That rear edge is looking good! Man I wish I went this route now. Then I wouldn't have the seam I have now on the bed floor, which would be great since I am not painting it to keep the originality of it.
Do the second set of mounts on your frame have the elongated holes in them for bolting the floor down? I find it curious that GM would eliminate the carriage bolts there in later trucks, since mine had them.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
06-06-2017, 06:35 PM | #29 |
Thanks, I'm happy with it so far. It is just the bed floor after all, and a common rot spot is eliminated this way.
My frame already has the holes in the 2nd row stands. It is a 68 frame. It had a long step bed on it originally, I don't remember if bolts were in there or not. It's been sitting since 2003 at my buddy's place in Wyoming.
07-27-2017, 08:08 PM | #30 |
I made a little more progress on the floor, the rear cross sill had some fairly large areas rusted out. I made some patches and welded them in. Nothing fancy, this is good practice for me, my sheet metal welding is a little rusty (haha).
After the patches, we did a little cleanup.
07-27-2017, 08:14 PM | #31 |
And a shot of the patches. One side is huge, the other is a little smaller. And no, I didn't do a lot of finishing work on these, they just need to be in there.
I'll hit them with some weld thru primer, which will be more than the factory did.
07-27-2017, 08:55 PM | #32 |
On the outer edges of the floor there's a cut out notch and the ribs in the metal are flattened out. I wasn't sure what to do with this area, so I figured that more hammer was the answer.
I used my RR track pieces as a backer to hold the shape of the long rib halfway and just started experimenting. I have a square face body hammer, it worked the best to form the corner and lay down the narrow rib. This is obviously different from the factory stamping, but it works for me. And it's not rotted away...
07-27-2017, 09:00 PM | #33 |
So, the shape isn't exactly the same, but it will work. Anyone that really knows these trucks will be able to see the difference. But at my level of skill, rescuing old junk on a skeleton budget, I'm happy with it.
07-28-2017, 06:50 AM | #34 |
Big Block
Look good to me. You're doing something most people would never attempt. You have the satisfaction of doing it yourself. Priceless.
07-28-2017, 07:51 AM | #35 |
I think it looks good!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
07-28-2017, 08:18 AM | #36 |
Thanks folks, it's been nice trying things out and having them turn out ok. If I was starting with something nicer I'd be reluctant for fear of messing something up.
Here's the sill pieces I cut out, just so anyone with the rear bed floor rust can know what is waiting underneath. The rot was definitely more extensive in the sill top than the bed floor.
07-28-2017, 08:21 AM | #37 |
looks great
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-20-2017, 01:08 PM | #38 |
Making slow progress, but it is coming along.
I drilled a hole in each rib to attach the floor to the rear sill. Before I plug welded each hole, I clamped the floor down to the sill. This helped even out the distortion caused when I hammered over the edge.
08-20-2017, 01:14 PM | #39 |
So, I now have the sill attached all the way across. The edge is pretty straight now, it's still not as uniform as the factory edge but I think this will work.
08-20-2017, 01:20 PM | #40 |
For a sanity check, I hung the bed sides on it. Everything measured out ok, but the proof is in the fitment when it comes down to it. It all lined up ok, so I'm happy with it.
This is also a good motivator for me, having a ton of unassembled parts on a truck that doesn't drive can be disheartening. It's good to see it look like an actual bed.
08-20-2017, 01:33 PM | #41 |
Just as reference for anyone wanting to do this, I used weld thru primer on the cross sill. The welds went better when I scraped away the primer with a pocket screw driver. I got some popping on the one I didn't scrape.
I didn't get all of it, but most. I figured it's still some protection since where I removed it is now a cooled weld puddle, and it's still on the remaining surface surrounding the weld area.
08-20-2017, 02:47 PM | #42 |
laying low
Not a thing wrong with that.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
