Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-06-2020, 03:02 PM   #1
KMC3420
KMC3420's Avatar
Sandblasting Door Actuators
Planning on sandblasting my door actuators and then Epoxy priming them. Is there a reason why it wouldn't be a good idea to sandblast them? I plan on hitting the pivot points with white lithium grease once primed.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 05-06-2020, 03:55 PM   #2
nsb29
nsb29's Avatar
Re: Sandblasting Door Acuators
I did mine they still work just have to get all the sand out
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 05-06-2020, 04:06 PM   #3
KMC3420
KMC3420's Avatar
Good deal, did you hit the "gear" as well? I don't see any bushings, just a pass through rivet that goes through the gear.
Keagan
Old 05-06-2020, 05:14 PM   #4
TKCR
TKCR's Avatar
I did mine also. Just make sure you get all the sand off. I rinsed them with the sprayer, in the sink. Then immediately blew them completely dry with the air compressor nozzle.
Old 05-06-2020, 11:50 PM   #5
KMC3420
KMC3420's Avatar
Sounds like a good plan and then set them out in the sun for a day.
Keagan
Old 05-07-2020, 05:40 AM   #6
TKCR
TKCR's Avatar
That wouldn’t hurt either. Your wanting to get all the sand cleaned out of the working mechanisms. I restore bench seats, which includes the tracks. You would be surprised what a few grains of sand can do. If all of it isn’t cleaned out, it will bind the mechanisms. And then the other important step, is making sure the part is completely dry.
The one step that hasn’t been discussed, is now that the part has been sandblasted, the door actuators are somewhat exposed to moisture. So a light coat of clear, or something, would help protect the part from re-rusting. And then of course, greasing/lubing all the working mechanisms.
Old 05-07-2020, 09:57 AM   #7
KMC3420
KMC3420's Avatar
I plan on epoxy priming for now as I am unsure of color choice at this point. What are you using to grease/lube them?
Keagan
Old 05-07-2020, 11:30 AM   #8
TKCR
TKCR's Avatar
Grease or lithium grease.
Old 05-09-2020, 04:53 PM   #9
LS short box
Maybe too late but I would soak them in lacquer thinner or some type of solvent for awhile to "melt" all the old grease out. Less places for the sand to stick to.
LS short box is offline   Reply With Quote
Old 05-09-2020, 08:23 PM   #10
TKCR
TKCR's Avatar
Good idea
Old 05-09-2020, 08:42 PM   #11
KMC3420
KMC3420's Avatar
Yep, too late but that is a great idea. I blasted them and then washed them in my kitchen sink yesterday. Sit them out in the sun all day today til it was about 65 degrees and hit them with epoxy. They are inside now to keep the epoxy above 60 degrees all night. I did hit them with my compressor air after washing and if I hit the gear mechanism at the right angle they would spin pretty fast. At that point I was satisfied they were quite clean.
SPI epoxy.
Keagan
Old 05-10-2020, 03:02 AM   #12
TKCR
TKCR's Avatar
Nice!! Good job
