05-20-2013, 07:11 PM | #51 |
Re: LVPhotos 1962 Build
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-20-2013, 07:12 PM | #52 |
05-20-2013, 07:59 PM | #53 |
Sounds good!
My frame Layin 63 short bed project http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
05-20-2013, 11:06 PM | #54 |
Senior Enthusiast
Very cool! Thanks for sharing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
05-24-2013, 05:13 PM | #55 |
Just in... Porterbuilt trailing arms. Taking donations to get more parts and powder-coat! Thinking chrome powder coat or a charcoal grey. Any other colors? Not black, white, red or pink? Truck is going to be Daytona Blue. Florescent green might not make the cut. Has to be "timeless" and likable years from now.
05-26-2013, 10:07 PM | #56 |
I can smell the rubber burning now sounds awesome
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
06-14-2013, 05:35 PM | #57 |
Primed the front fenders.
08-21-2013, 07:38 PM | #58 |
Working in the garage on the rear tubular trailing arm from Porterbuilt. Bags at 80psi full up.
08-21-2013, 07:43 PM | #59 |
Out with the old boxed and powder coated originals in with Porterbuilt tubular extended 1/2" bars. This will center the axle in the wheel house. Yes there is daylight in one shot but the bolts were hand tight.
08-21-2013, 07:46 PM | #60 |
Still on jack but tucked all the way. No bump stops or pipe notch. Yet.
08-22-2013, 02:19 PM | #61 |
nice man looks good
08-23-2013, 04:55 PM | #62 |
Cut the pan-hard bar mount off. Reposition the rear. Did valve cover swap, with hint of the body color. Full down on frame and fender, time for a nip/tuck and pipe notch. Swapped in the MSD Distributor and coil, no more HEI.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 08-23-2013 at 05:18 PM. |
08-25-2013, 08:22 PM | #63 |
Post on trailing arms not working. What's a good price range for the ones I pulled off?
09-05-2013, 07:37 PM | #64 |
Workin!
10-25-2013, 12:12 PM | #65 |
Some updates. Dragged a 4 door dualy to buddy's house. Applied GM engine decals. The 400 is early Caprice which is right size and car wrong year. The 400hp is for the 409. Test fitting Porterbuilt bar and frame mount. Now the axle sits 1/2" back the new mount is relocated rear of crossmember about where the 63-72 is.
10-25-2013, 12:36 PM | #66 |
1962 C-10
I like! Very cool project...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
10-25-2013, 03:36 PM | #67 |
Looking sharp!!! Awesome!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-11-2013, 06:13 PM | #68 |
Found this initial measurement of rear ride height with 275-60-15s minus bed weight.
12-19-2013, 01:28 PM | #69 |
since cardomain is now jacked here are exhaust pics
http://carphotos.cardomain.com/ride_...iginal.jpg?v=0
12-19-2013, 01:29 PM | #70 |
12-19-2013, 09:31 PM | #71 |
Sure as heck is alot cleaner under there then my truck is! LOL!
12-19-2013, 10:36 PM | #72 |
Cool build. Do the PB rear arms drop it any over using stock or just move the axle location?
GOD BLESS AMERICA! |
12-19-2013, 11:27 PM | #73 |
Built in L.A. and has been in Nevada most of its life. Few months in AZ when I was in college.
12-19-2013, 11:32 PM | #74 |
I believe they have 1" built in but you can get 3" ones. I plan to pipe notch and not go more... for now. They solve the centering of wheels and axle angle.
01-02-2014, 09:57 PM | #75 |
Rearview.
Tags |
1962 chevy, bagged c10, manual transmission, short bed c 10 |
