10-20-2004, 12:17 AM | #1 |
What to look at?
I'm going to look at a 69 4X4 Blazer this weekend. I was wondering what kind of things I should look at that has trouble in these Blazers. Spots that rust out, suspension problems, top troubles, etc. Thanks in advance.
10-20-2004, 12:52 AM | #2 |
Hey good to see another B.C. member. these blazers rust everywhere the rocker boxes,front window frame and window supports/kick panels.the best thing to do is check out members progres pics and threads.That will give you a good idea what to look for. Good luck
10-20-2004, 11:55 AM | #3 |
SKINNY TIRES RULE!
Check the top for splitting too. If it is a double wall top, they tend to split.
'69 may have either the Dana 20 or NP205 t-case, depending on the transmission. Both are good t-cases, but the NP205 is stronger. Check the ball joints, tie rod ends, etc. It should have drum brakes upfront, but they are often swapped out with '71 or '72 disc front axles. Check the frame around the steering box, especially if it has bigger tires on it.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
10-20-2004, 01:00 PM | #4 |
Here is a similar thread.
http://67-72chevytrucks.com/vboard/s...ghlight=blazer Hope it helps and good luck!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
