11-19-2013, 07:02 PM | #26 | |
Re: Winter Beater Build- '66 BBW Custom Short/Fleet with Heat!
I picked up a pretty nice gas tank for $20 bucks today, and deluxe heater with inside air duct, controls, and cables for another $20. Not sure yet if I'll convert it to a deluxe heater or save that for Goldilocks. Shot of the inside of the tank. I'll clean it with muriatic acid to get the rust out before installing it. Also peeled back the newer seat covers to find that the original cover is still there. Hopefully the base is decent enough to live with, the vinyl cover that's on it is pretty nasty looking.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-20-2013, 09:16 AM | #27 |
Subscribed. nice original seat.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
11-20-2013, 10:16 AM | #28 |
Super nice find!!!
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
11-20-2013, 12:03 PM | #29 |
[QUOTE=theastronaut;6372829]I posted in a few "for sale" groups on facebook that are local, someone should have them close by. We do a good bit of glass work for a local shop that installs lift kits, they should have a set.
I picked up a pretty nice gas tank for $20 bucks today, and deluxe heater with inside air duct, controls, and cables for another $20. Not sure yet if I'll convert it to a deluxe heater or save that for Goldilocks. Shot of the inside of the tank. I'll clean it with muriatic acid to get the rust out before installing it. When you run the muriatic acid through the tanks are you coating the inside with anything after to prevent rust again ? I need to do a couple Suburban tanks.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
11-20-2013, 12:08 PM | #30 |
I would have gotten rid of the slider too....don't care for them personally unless theres a camper on the back.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-20-2013, 07:43 PM | #31 | |
Yeah, it just looks out of place on the truck.
11-20-2013, 07:49 PM | #32 |
Picked up a pair of free jeep springs today and also a fuel sending unit. Going to pull the seat, tank, and old fuel lines tomorrow after work.
This is the look I'm going for, except I'll keep the original caps.
11-20-2013, 09:32 PM | #33 |
Then drive the wheels off of it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-21-2013, 09:35 AM | #34 |
I love the Cropwell truck.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-21-2013, 08:39 PM | #35 |
Pulled the seat and tank tonight, then cleaned all the trash out... in the rain.
The interior is nasty, definitely my least favorite part of the truck. The floormat is in decent shape though, so I'll pilfer it and use it in Goldilocks until reproductions are made or I find a NOS mat.
11-21-2013, 08:42 PM | #36 |
Well at least your rust issues don't seem to bad...my has holes all along the rocker panel.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-21-2013, 08:42 PM | #37 |
What no worth while memorabilia
11-21-2013, 08:52 PM | #38 | |
Nothing noteworthy. There was a slim stainless ruler that we'll keep, that's it.
11-21-2013, 10:41 PM | #39 |
Have you ordered all your Porterbuilt stuff yet? As I understand it that stuff takes a while to come in.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
11-21-2013, 10:44 PM | #40 |
nice find!
My frame Layin 63 short bed project http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
11-21-2013, 10:56 PM | #41 |
I'm not sure what you're taking about? The wait time on the Porterbuilt TJ mild rear drop kit was pretty short, had them only two days after I placed my order on Craigslist. I already had his "Choose Your Drop" front coil kit in the barn loft, lost the instructions that said "Cut X amount of coils for X amount of drop" though. Would appreciate if anybody could pm those ASAP!
11-21-2013, 11:35 PM | #42 |
PDf on it's way
11-21-2013, 11:36 PM | #43 |
I had the "Choose your drop" instructions on a PDF on my last computer but a bad beer accident nixed that. Sorry!
So you went with the TJ coils? I have heard so much either way about using them for a rear drop. Some have said they did a good drop, others said they didn't do anything. Almost everyone speaks of the loss of payload ability. I think its truck dependent. Meaning, how much the truck was used and what kind of sag it has. You truck looks to be in great shape and sits pretty high so it will be a good candidate to settle the TJ coil mystery once and for all. Take measurements!
11-21-2013, 11:38 PM | #44 |
^^^Duallyjams beat me to the PDF punchline! LOLOL!
11-22-2013, 12:28 AM | #45 |
Your truck looks like it is in pretty good shape overall. Get the few things done to it and then drive the wheels off of it...I hope to find one like it someday, good luck with your new find!
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
11-22-2013, 11:50 PM | #46 |
Man truck looks really good, can't wait to see the rest
11-29-2013, 07:46 PM | #47 |
Worked on the fuel lines today and cleaned the tank.
We bought Eastwood's tubing flare set awhile back as haven't used it yet so I tried it out on the pump-to-carb line. Works great! After bending, flaring, and installing line from the FLAPS. New pump, flex lines, and filter. Drying out the tank. Found out why the shifter doesn't work...
11-29-2013, 08:52 PM | #48 |
1) your not stuffed from Thanksgiving
2) it's always fun to get to use new tools 3) still has the ground strap from the valve cover to the firewall
11-30-2013, 09:58 AM | #49 |
Very nice truck
12-06-2013, 04:51 PM | #50 | |
Thanks!! The filler neck and grommet came in today so I painted the tank and got it ready to install. Should have it in and running tonight.
