05-20-2009, 07:32 AM | #1 |
Something is amiss
Now that I'm clearing up my wiring to make sure I'm street legal with lights, signals, and the like. I'm digging into that and this is where I stand.
new headlight switch and dimmer switch, new taillight wiring from cab back. New taillight assemblies. For some reason my signals aren't flashing yet they will turn on. Brake lights light when I press the brake, but only on the driver side. I installed a new turn signal switch and got a new flasher, but I'm thinking it may be faulty. Why else would I have light when I press the turn signal, but no flashing. It stays on. I'm rewiring the connector on the passenger side turn signal, which I'm sure is the reason why its not lighting, but any clue as to why the passenger side taillight isn't lighting? |
05-20-2009, 05:31 PM | #2 |
Bloodied Knuckles
Re: Something is amiss
if your using the old plugs with just new wire leading to them you may have to clean the contacts a bit... other than that, I would guess you just need to make sure your wires are connected right and your bulb is good. I replaced a bulb not long ago and i had to push the plug on and pull it off several times before I cleaned the contact enough for it to work... as far as your flasher goes... pick up another flasher relay, they are cheap and you know you have power going to the signal so.... I also just recently had a problem with the crimp on style wire connectors, if you are using these make sure you give your wires a good tug after they are crimped... with as much headache as these have cost me, I will never use another crimp on wire connector unless I physically cannot solder the connection. Good luck to ya sir..
05-21-2009, 03:04 PM | #3 | |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: Last edited by seldomseen65; 05-21-2009 at 03:06 PM. |
