Old 12-20-2012, 12:51 AM   #1
heathbirkendahl
Clutch fan or flex fan?
Is it worth running a flex fan vs. a clutch fan?
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 12-20-2012, 01:22 AM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Clutch fan or flex fan?
If the truck has AC don't even consider it, if not it may be OK. I haven't had much luck with the flex blades though.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-20-2012, 01:34 AM   #3
PAWS 72
PAWS 72's Avatar
BEEN ON MINE SINCE DAY 1.But been wondering about a flex fan I think it would be quieter.
PAWS 72 is offline   Reply With Quote
Old 12-20-2012, 01:44 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
In the 35 years I've owned my truck the only time it ever ran hot was when I temporarily had a flex fan on it. No problems ever with a clutch fan. Mine is OEM with an 18" seven-blade fan (factory A/C). I will never recommend a flex fan.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-20-2012, 01:57 AM   #5
heathbirkendahl
No A/C and it sounds like I need to forget the flex fan idea. Electric fans with the 4 core it is.
Old 12-20-2012, 02:25 AM   #6
Mick Je
Mick Je's Avatar
I would keep the clutch fan on if you still use your truck in hauling stuff and towing up steep grades ,and on long trips. A flex fan is good for around town drives and if you don't use your A/C a lot during hot weather conditions. I have a Perma Cool flex fan and I wish I would of got a new clutch fan.
343 NEVER FORGET 9-11
FIGHT ON!!! GO USC!!!
PROUD OWNER OF A 1970 1/2 TON
Mick Je is offline   Reply With Quote
Old 12-20-2012, 02:39 AM   #7
PAWS 72
PAWS 72's Avatar
Been wondering about that. Mine doesn't have ac.
Old 12-20-2012, 02:46 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
When my truck ran hot with a flex fan (posted above) I wasn't running the A/C.... but I was hauling a load of firewood uphill. Might have been OK if I just drove around but not when gets worked like a truck, which mine still does.
- Mike -
RIP El Jay
Old 12-20-2012, 02:56 AM   #9
bk2life
flex fan quieter? lol
nope, abuot a billion times louder than a clutch fan.
bk2life is offline   Reply With Quote
Old 12-20-2012, 07:28 AM   #10
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Every so often I like to post these pictures of my truck that HAD a flex fan on it. It was on the truck when I bought it and I will never use one again for obvious reasons!
Note, the strange looking hood ornament! (could have been my skull!)
BTW, that didn't just go through the flat sheetmetal but half way through the support under it!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-20-2012, 08:23 AM   #11
Hubscrub
Cruzin
Hubscrub's Avatar
I ditched my flex for a factory type clutch fan , im not much on electric just more stuff to fail
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-20-2012, 08:32 AM   #12
shawno72
C/10 junkie
shawno72's Avatar
I have a flex fan now and will be switching to a fan clutch real soon.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-20-2012, 09:01 AM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
Reasons NOT to have a flex fan:
1. See photo above from bobs409
2. They are very noisy while on the gas.
3. You need kevlar gloves and sleeves to work around them. Very sharp.
4. They rob horsepower.
TBONE1964 is offline   Reply With Quote
Old 12-20-2012, 09:19 AM   #14
mrein3
mrein3's Avatar
The very first thing I did to my convertible when I bought it in 1989 is take that noisy, POS flex fan off that the PO put on. It made no sense to me then. After seeing that fan stuck through that hood, it makes even less sense. You could be working on it when a blade comes off. That could be your head!
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-20-2012, 09:34 AM   #15
69GWC
My truck had the stock steel fan on it and it was very loud so I switched it over to a 18" clutch fan and it is so much better now and the flex fans are still noisy at low rpms.
69GWC is offline   Reply With Quote
Old 12-20-2012, 02:22 PM   #16
MARKDTN
Car Craft Magazine article, May 2000, page 50 and 51
Dyno test on fans:
alternator, no fan=496 HP
plastic flex fan=460 HP
low profile flex fan=466 HP
High-performance flex fan=476 HP
Rigid steel 6-blade fan=449 HP
Rigid steel 4-blade fan=473 HP
Thermal clutch fan=487 HP
non-Thermal clutch fan=485 HP
HD Thermal clutch fan=476 HP
alternator, electric fan (Black Magic 150)=494 HP
So, stay away from any rigid fans and flex fans. On their engine the clutch fan only used about 10 HP as opposed to 30 for a flex fan. The electric fan only used 2 HP!
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-20-2012, 02:30 PM   #17
Longhorn 70
Longhorn 70's Avatar
I wonder about the reliability. I have had thermal clutch fans fail and had to take them off and bang them with a hammer to lock up just to get home. I did also have a fiberglass flex fan come apart, while I was at idle thank goodness. It only banged out through the bottom.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-20-2012, 02:42 PM   #18
ole dollor
ole dollor's Avatar
rigid style fans and flex fans do come apart and do use more gas.and are very noisy . i always try and go with fan clutch fans....that is not the first hood with a fan sticking through it that i have seen....ask ford motor company back in the 1970's....they have stacks of broken fans...
ole dollor is offline   Reply With Quote
Old 12-20-2012, 07:10 PM   #19
Frkypunk70
Frkypunk70's Avatar
I had a fan sticking through my hood and it was a clutch fan. Now I run an electric one....problem solved!
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 12-22-2012, 03:20 PM   #20
dropanddrag71
dropanddrag71's Avatar
Tossed out my flex fan and got a clutch and clutch fan from summit. 18" flx-5718 and hda 2705 .. Love it, simple to install... your real question should be, thermal or non thermal clutch fan? Hope i dont insight a riot!! good luck!
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
Old 12-22-2012, 05:31 PM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ Thermal, of course!
- Mike -
RIP El Jay
Old 12-22-2012, 08:29 PM   #22
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
take those POS flex fans off ASAP just sayin' never did like them any fan blade really ,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 12-22-2012, 08:45 PM   #23
crazy longhorn
Fabricate till you "puke"
That pic is worth a couple thousand words.....think about standing over that engine (tuning)? Buzz the throttle a couple times (like we all do)....the hood was cheap to replace? That blade stuck in your head, would not be so good crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-23-2012, 09:17 AM   #24
Hubscrub
Cruzin
Hubscrub's Avatar
i think about this now alot (older and smarter) all that moving stuff could mess you up i've heard of the piece behind of the alternator pulley breaking and messing a guy up. i've had my hand smacked by a fan and thank God it wasn't a flex fan still numb for a couple hours.
Proverbs 3:5,6
