03-28-2015, 07:32 PM | #1301 |
Re: Restoring Rusty
WOW you are really a jack of all trades kinda guy, good to see some more progress
03-28-2015, 10:11 PM | #1302 |
Re: Restoring Rusty
Originally I had it hanging the other way, but the bungee cords kept rubbing against the front lip, so I flipped it upside down, I had to lay on my back on the ground and shoot the front of the hood that way, the entire operation was a major PIA I also had to squeez in on the sides to paint the sides of it
03-28-2015, 11:05 PM | #1303 |
Re: Restoring Rusty
Aaah, that makes sense. Well hey, you got it done!
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
03-29-2015, 02:47 PM | #1304 |
Re: Restoring Rusty
Looks good man. I can't wait to see how the hood turns out. My hood is bent so bad it looks like a "U". Almost but not all the way...lol.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-29-2015, 07:35 PM | #1305 |
Re: Restoring Rusty
Hope you don't get bugs in the paint. Should have draped mosquito netting over the ole swing set.
03-29-2015, 08:23 PM | #1306 |
Re: Restoring Rusty
03-29-2015, 08:26 PM | #1307 | |
Re: Restoring Rusty
I will share some more pics once it's on the truck and out of the garage |
03-29-2015, 08:36 PM | #1308 |
Re: Restoring Rusty
not sure you guys seen my other thread called Truck Won't Start No Sounds No Noises Nothing it's what has been keeping me busy and sleepless the last few days and nights
anywho since it deals with the ignition I will share some pics of me tearing up the steering column area so we can see what lurks beneath |
03-29-2015, 08:46 PM | #1309 |
Re: Restoring Rusty - Ignition Switch
couple more shots of the ignition switch itself
on mine not all the blades are used, I'm sure yours will differ |
03-30-2015, 05:13 PM | #1310 |
Re: Restoring Rusty
Could this been the problem with your truck not wanting to start the first go around? Little electrics are a pain in the butt aren't they.
03-30-2015, 07:05 PM | #1311 | |
Re: Restoring Rusty
I think a broken Ignition Lock Cylinder is more like the culprit as the end part has broken into three pieces, it is that part that pushes on a metal rod which runs down the steering column down to the actual ignition switch, it's how they did back in the day, when Mechanical Solutions ruled the world |
03-30-2015, 08:38 PM | #1312 | |
Re: Restoring Rusty
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
03-30-2015, 09:18 PM | #1313 |
Re: Restoring Rusty
Damn you're good
03-30-2015, 09:35 PM | #1314 |
Re: Restoring Rusty
03-30-2015, 10:38 PM | #1315 |
Second Chance Program
Re: Restoring Rusty
Hood turned out nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
03-30-2015, 11:02 PM | #1316 |
Re: Restoring Rusty
did the lock cylinder fix the problem? otherwise it could be a broken ignition rack or that plastic gear. (little more down the column)
03-31-2015, 12:29 AM | #1317 |
Re: Restoring Rusty
03-31-2015, 12:32 AM | #1318 | |
Re: Restoring Rusty
here's a pic of that sector gear with one tooth missing |
03-31-2015, 12:54 AM | #1319 |
Re: Restoring Rusty
Oh my goodness.
03-31-2015, 01:00 AM | #1320 | |
Re: Restoring Rusty
By the way the hood turned out great!
03-31-2015, 02:01 AM | #1321 |
Re: Restoring Rusty
for anyone wanting to see a in depth view of the steering column being taken apart:
http://forum.73-87chevytrucks.com/sm...?topic=12525.0 |
03-31-2015, 02:19 AM | #1322 |
Re: Restoring Rusty
03-31-2015, 02:26 AM | #1323 |
Re: Restoring Rusty
found this page on the interwebs that explains what each wire does on the turn signal switch wiring harness ie the non ignition switch wires that run up the steering column
this isn't the exact part / plug match but the wires seem identical, so it might could help somebody out, I know it beats the wiring schematics for me anyways white - stop lamp switch (what is that?) green - right rear turn signal yellow - left rear turn signal purple - turn flasher (what is that?) brown - hazard flasher dark blue - right front turn signal light blue - left front turn signal black - horn |
03-31-2015, 02:40 AM | #1324 |
Re: Restoring Rusty
this shows what the pins on the ignition switch are, mine doesn't use all of them but the ones that it uses match
03-31-2015, 02:47 AM | #1325 |
Re: Restoring Rusty
Diagram of the two plugs the white one and the black one that plug in to the ignition switch and what they do
WHITE CONNECTOR Pink - Start & Run (connect this to the ignition) ... Pink is ignition, pink is ignition, pink... Purple - Start (connect this to the starter solenoid)... Purple is starter, purple is starter... Red - This is the Battery connection bringing power into the switch. Red is usually power, red... Brown - Accessory & Run (Accessories....) BLACK CONNECTOR Red - This is the Battery connection bringing power into the switch. Orange - Run (connect this to power anything in the Run state) I also have a Dark Brown / White Stripe wire going here, not sure what it's for Light Brown / Black Stripe - Start position switches this lead to ground Last edited by Gregski; 03-31-2015 at 03:15 AM. |
