Old 07-07-2011, 10:28 AM   #1
doodah man
doodah man's Avatar
low hanging exhaust???
Does this mid-section of the exhaust look like it's hanging too low? I don't know what's normal, but it looks a little exposed to me. The end of the exhaust is also right up against the bottom of the rear fender and angled slightly up. That doesn't look quite right either.
TIA.
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 07-07-2011, 10:36 AM   #2
cdowns
cdowns's Avatar
Re: low hanging exhaust???
i've always just loosen things up and by pushin here and there and using good hanger system then retightened ,adjusted for alot better fit than that
Old 07-07-2011, 10:53 AM   #3
KEL
72 GMC
KEL's Avatar
nice lookin' truck, though
KEL is offline   Reply With Quote
Old 07-07-2011, 04:16 PM   #4
doodah man
doodah man's Avatar
Thanks KEL.
I'm going to try fiddling with the hangers and see if I can get it raised up some.
1972 C-10 Deluxe
350 V8 - 350TH
Old 07-08-2011, 10:23 PM   #5
68 IRON
68 IRON's Avatar
Kinda looks like mine.....
68 IRON is offline   Reply With Quote
Old 07-08-2011, 11:33 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Saddly, they all look like that, & mine did too until last week when I did the typical conversion where you drill two 4" holes in the trailing-arm cross member, weld some tubing in there & route the exhaust through it.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 07-09-2011, 07:43 AM   #7
cdowns
cdowns's Avatar
the people i've seen that put exhaust thru the crossmembers have also boxed them so as to strengthen them so that they dont fail// not just drilled big holes and weakened the crossmember
Old 07-09-2011, 11:28 AM   #8
bosco200
bosco200's Avatar
Mine is the exact same....nice truck!
bosco200 is offline   Reply With Quote
Old 07-09-2011, 03:33 PM   #9
s102000
Here is the exhaust on my 69 gmc, the system is routed and tucked up between the frame rails and the body for a cleaner look from the side.
s102000 is offline   Reply With Quote
