11-21-2017, 11:57 AM | #1 |
Tire rim for spare advice on 66
Ive bought the tire bracket for the spare that suspends under the truck and was going to have it sandblasted and painted. But I dont have a spare for it yet. The rims are rally 15 x 8 w 6 lugs and Ive got front disc brakes. The long bolts that hold the tire to the bracket are about 9 inches from the base of the bolt head to the end of the threads. For the spare what should I hunt for? The same or would I need something more narrow width to fit under the truck bed?
Heres a pic of the rims i have |
11-21-2017, 03:07 PM | #2 |
Re: Tire rim for spare advice on 66
That wheel is a good bit wider than the one the truck came with and the hanger bolts will be to short. The original wheel would have been 15X5.5. There are threads in the FAQ sections on wheels and I think there is a 15X6 wheel that will clear the disc brakes.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-20-2018, 08:20 PM | #3 |
Since my truck is still dismantled and and in repair I'm not in a big rush for the spare, but as I get closer to being done it would be nice to get a spare.
I have looked through the FAQ on spare tires and havent yet seen the mention of whether the 6 inch wide rim will clear the disc brakes. I have been searching for 15 x 6 chevy 6 lug rims. I did find this one and found that it was actually 16 inch and it has 6.00/16 tire on it. Would the difference of rim size make it dangerous to count on? |
03-20-2018, 10:31 PM | #4 |
I don't know why rim size would matter much in temporary use. Remember lots of cars have "space saver" spares which are a different diameter than the other wheels.
03-20-2018, 11:09 PM | #5 |
I have a 15x8 rally wheel with a 235/75 tire, and it did not fit with the stock spare bracket. My truck still had the factory carrier, and I did attempt to use it. I used the advice on this site to fit a 90s Nissan D21 spare tire hoist (chain style), and it worked great. Now I have a full size spare that I could run on for a while if I had to, and it is so much easier to get to the spare if I ever need to.
Sorry for the sideways pic, don't know how to change that.
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-21-2018, 09:37 AM | #6 | ||
03-22-2018, 02:13 AM | #7 | |
