Old 04-18-2023, 03:46 PM   #1
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
What is best to put on threads of the plug to the master brake cylinder
I read that brake fluid does not like teflon ,,so what does that leave that will make the plug threads tight ? and one can take it back out when needed .
Please do not make this political ,,lol
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 04-18-2023, 04:02 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: What is best to put on threads of the plug to the master brake cylinder
Shouldn't need anything.
The seal is intended to take place between the flare on the end of the pipe and the corresponding seat inside the master cylinder port.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-18-2023, 04:10 PM   #3
GOPAPA
GOPAPA's Avatar
K
I have a big nut that screws directly into the top of the ,,,,,,,,,,,master cylinder ,,must have the last thread stripped as it just keeps on turning ,, do not have a flare and pipe .
Old 04-18-2023, 06:22 PM   #4
Keith Seymore
Pic?
1979-1986
1986 - 2019
Old 04-18-2023, 07:11 PM   #5
GOPAPA
GOPAPA's Avatar
[QUOTE=GOPAPA;9197499]I read that brake fluid does not like teflon ,,so what does that leave that will make the plug threads tight ? and one can take it back out when needed .
Old 04-19-2023, 08:43 AM   #6
Keith Seymore
Well - that was...unexpected.
I think we need to back up a few steps.
What vehicle is this?
What does that big nut do (ie, attaches the M/C to the vehicle, or holds the lid on)?
Is this part of the factory set up, or modified?
Why am I the only one participating?
At this point - I might suggest something like Permatex Aviation Form a Gasket, but might feel differently after you answer the above questions.
K
1979-1986
1986 - 2019
Old 04-19-2023, 09:48 AM   #7
GOPAPA
GOPAPA's Avatar
Sorry Keith ,I guessed all knew I had a 39 chevy,, should of not thinked that,,, getting older and am selling this car ,,memory is the reason..it is a master cylinder on a stock brake set up for that year,, the big ol nut /plug is what you take out of the master cylinder to fill the master cylinder with brake fluid ..
The plug screws down the threads until the end and then just turns like the last thread is ruined ,, it has a rubber 0 ring but that does not stop fluid from oozing out when appying the brake peddle .. either I'll get a thicker 0 ring or
I will try the Permatex Aviation Form a Gasket if I feel that it will not get into the cylinder and foul up my brake system.. still open for ideas on this .
Old 04-19-2023, 05:00 PM   #8
MySons68C20
MySons68C20's Avatar
Is the O ring captive in a groove or does it locate on the flat of the nut?
I'm thinking a thick washer and then the fatter O ring so you stay away from the stripped portion of the threads.
MySons68C20 is offline   Reply With Quote
Old 04-20-2023, 10:38 AM   #9
chevyguyase
It's just a cap (lid) there should be no pressure on the lid. Don't fill it to the top. when you press down on the brake pedal the fluid level will go down a little and when you let up on the pedal the fluid will return to the reservoir. The lid should just be "snugged" up. it may even have a tiny vent hole in it. Watch this YouTube video. you can go to the 23.00 min mark when he puts the top plate and cap on it.
https://youtu.be/igZgswGAvi8
chevyguyase is offline   Reply With Quote
Old 04-20-2023, 09:01 PM   #10
GOPAPA
GOPAPA's Avatar
That is about like mine and maybe just like mine .. I did not see a rubber O ring ,,the plug looks just like mine ,, maybe the rubber O ring was already on the Plug ..my plug or cap as you call it has a hole from underneath that goes up inside the plug and then out the side of it .. if you full the cylinder to full and put the plug in,, then push the brake peddle it will pump brake fluid out the hole in the side of the plug.. I realize the hole is to let air in when you pump the brake .. good video ,, thx I will take the plug and start over and maybe use a bigger O ring or something.
Old 04-20-2023, 10:16 PM   #11
chevyguyase
I wouldn't worry about the O-ring. Just suck out about 1/2 inch of fluid. I figure 1/2 inch because the top plate and threaded portion is probably 1/2 inch thick and you want at least 1/4 inch of air between the top plate and the fluid. I think you are putting to much fluid in it. It has to have air space in the master cylinder. No fluid should be near that lid. As long as it keeps dirt out and returns fluid splashed up while you're driving you're good to go. There is no pressure on that lid, it has to vent. Have fun my friend.
Old 04-21-2023, 08:12 AM   #12
GOPAPA
GOPAPA's Avatar
Great advice ,,I learn all the time with things I hardly ever fool with..with all this good help maybe I can pass it on to another
Old 04-21-2023, 10:32 AM   #13
chevyguyase
Glad I could help. I also try to " store up smart". I'm an old man and doing this professionally all my life. Even in the army I was a mechanic. I still learn a lot from all the talent on this site.
