Old 08-16-2019, 10:14 AM   #26
dmw319
Re: Fixing body lines on my 70 c10
so.. my door still pops. and I don't know what to do short of taking an angle grinder to shave part of it off (its that annoying).
I don't seem to have any room to move the door back towards the cab any further (if you look at this pic: https://savedalone.files.wordpress.c...1/img-6896.jpg
anyone have any ideas?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 08-16-2019, 10:22 AM   #27
Grumpy old man
Grumpy old man's Avatar
Check your core support mounts . you just may be able to use one shim on the passenger side to lift the fender away from the bottom of the door if the mount is still good . it's not the door it's the fender that's dropped .
Old 08-16-2019, 11:39 AM   #28
ga-stepside
ga-stepside's Avatar
That is exactly what I had to do.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 08-20-2019, 08:02 AM   #29
dmw319
thanks! my cab mounts are shot so I'm going to start with replacing those and seeing what happens
Old 08-22-2019, 10:04 PM   #30
Mbeef61
Mbeef61's Avatar
Do the core supports also
Mbeef61 is offline   Reply With Quote
