Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-18-2018, 09:23 AM   #1
Ricks1971
Ricks1971's Avatar
help starting a 72 C10
I inherited a 72 C10 longbed from a friend who passed away. He has messed up the wiring really bad as he wired a homemade alarm system and he wired a second battery and switches everywhere. How can I hotwire this truck to get it started by bypassing all the stuff he did? Thanks Rick
Ricks1971 is offline   Reply With Quote
Old 07-18-2018, 11:33 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: help starting a 72 C10
I would start by removing the alarm system and everything that goes with that.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-18-2018, 09:14 PM   #3
Ricks1971
Ricks1971's Avatar
This old guy has toggle switches everywhere and a two battery setup. I just want to get it started so I can sell for the relatives
Old 07-18-2018, 10:13 PM   #4
dmjlambert
dmjlambert's Avatar
It looks like your friend's plan of preventing hot-wiring is working. I think you would have to trace all the wires, and figure out how his wiring compares to the original wiring, and toggle the switches to appropriate positions or eliminate them. Somebody trying to steal the truck would presumably not have ample time to figure all that out and get it started before somebody walked outside with a shotgun or turned the dogs loose. :-)
The wiring:
http://67-72chevytrucks.com/vboard/s...&postcount=302
Old 07-19-2018, 08:42 PM   #5
starterman99
starterman99's Avatar
It all really depends on how much work you want to do or are capable of.If all you want is to make it run you need power to + side of coil remove power from coil engine dies.and a way to activate starter S terminal on solenoid to make it crank. If you want to make it more than temporary then you can wire it thru a push button to activate starter and a off on switch for ignition with a balast resistor in the circut to coil. even better repair wiring to and from original ignition switch.
1950 5 window
starterman99 is offline   Reply With Quote
