Old 06-14-2015, 09:50 PM   #1
tjsblazer
tjsblazer's Avatar
Question Fuel tank anti squeak rubber help
Due to time, I had someone else strip my chassis. So I'm not sure which way these things came off.
The pic below shows the 2 rubber squeak pads that were between edge of the fuel tank and the bracket that sandwiches between the tank and the frame.
Why are they long and triangular at the one end?
Which way does that face, forward or rearward?
The assembly manual doesn't really show them that well.
Thanks for any help.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-15-2015, 01:07 AM   #2
vancelot69
vancelot69's Avatar
Re: Fuel tank anti squeak rubber help
that looks like a piece of innertube that someone cut up. The replacement tank kit I got came with some anti squeak felts that look like roofing felt that I just laid across the fuel tank lip and pinched it between the tank and the frame.
I'm not sure if I did it right by not running the bolts through the holes on the tank, but the way I did it is how they were ran when I took the old tank off, and it's been staying put *knocks on wood*.
My toys:
1971 GMC Jimmy
2008 Hummer H3 Adventure
2003 HD Road King
vancelot69 is offline   Reply With Quote
Old 06-15-2015, 09:50 AM   #3
Minnz
Minnz's Avatar
Mine tank was replace by the PO and the anti squeak pads were reused. They look exactly like the ones you show. This photo somewhat shows how they fit.
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
Old 06-15-2015, 11:06 AM   #4
tjsblazer
tjsblazer's Avatar
Thanks for the feedback. I think the replacement kit has different pads than factory. I have seen a few with the shape and material of mine. I don't think they left the factory with any fasteners except for the straps. At least that is all the Assembly manual shows. I have seen people add bolts through those holes when doing a replacement.
I appreciate the picture. Looks like at least on that passenger side photo it goes towards the front.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-15-2015, 01:15 PM   #5
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Member Seventyone lent me his originals to make mock ups using a Neoprene Sheet, 60A Durometer that I bought on Amazon for 20 bucks. It's .125" thick and 6" wide and 36" length that you can cut to form the same shape as your originals. I have them installed but I can't confirm they actually keeping them from squeaking.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 06-15-2015, 01:46 PM   #6
tjsblazer
tjsblazer's Avatar
Were they triangular on the one end? Which way did you point that elongated end?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-15-2015, 01:59 PM   #7
72K5CSTDarkOlive
Yep, just like the ones you have there. I'll have to double check and see which way I have them pointed.
Old 06-15-2015, 09:39 PM   #8
72K5CSTDarkOlive
I have mine pointed to rear. There wasn't any particular reason why I did it this way so cant say for sure if it's correct. My tank is completely bolted down and the front (where the rest of the edge of the tank is exposed) has about a 1/4' space between the frame rail. Hope that helps
Old 06-15-2015, 10:43 PM   #9
69-72
69-72's Avatar
Here are what I found to be the original GM rubber
http://www.ebay.com/itm/111649326447...%3AMEBIDX%3AIT
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 06-16-2015, 06:57 PM   #10
tjsblazer
tjsblazer's Avatar
Well I ended up pointing mine rearward also. Only way they really follow the contour of the tank. No idea what purpose it serves after it sticks out from the bracket but looks like they came from the factory that way.
Thanks for the link I might have gotten some of these for the straps had I known but I just cleaned up and reused the originals.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
