Old 05-06-2020, 10:06 PM   #1351
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Update:
These next few shots are of the headliner and the trim pieces above the doors for the headliner.
First 2 shots are the trim pieces made
The 3rd is the headliner after it was prepped for the material.
The last 2 are the final look.
It was wrapped in suede.
Mark
reaper71 is offline   Reply With Quote
Old 05-06-2020, 10:19 PM   #1352
Jason 56
Looking good!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 05-06-2020, 11:34 PM   #1353
oldman3
oldman3's Avatar
Looks good...Dad
oldman3 is offline   Reply With Quote
Old 05-07-2020, 08:34 AM   #1354
skymangs
skymangs's Avatar
Awesome Mark!
skymangs is offline   Reply With Quote
Old 05-07-2020, 09:03 AM   #1355
8man
That interior is beautiful!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-07-2020, 10:45 AM   #1356
rollinrooster
rollinrooster's Avatar
Originally Posted by youngrodder View Post
Looks great Mark...I like your intake color. Is that a titanium color? The engine bay looks nice and tidy. The custom radiator shroud is a nice touch too..
Marc
Just came across this build, been away for awhile. Anyway truck is NICE!!! Love the radiator shroud as well. Also would be interested in the belt sander plans it came out great!! Keep up the good work.
rollinrooster is offline   Reply With Quote
Old 05-07-2020, 10:51 AM   #1357
rollinrooster
Mark, any pics of the battery install? Im still trying to figure out where to put mine. Planned to but it under the bed floor but space is premium under there.
Old 05-07-2020, 07:16 PM   #1358
reaper71
reaper71's Avatar
Thank you everyonefor the compliments!
Old 05-07-2020, 07:22 PM   #1359
reaper71
reaper71's Avatar
rollinrooster, speakingof the belt sander...
Pic 1. Primer
Pic 2. Synergy green over silver.
Pic 3. Sander back together with matte clear.
The plans for the sander...are still coming sorry for the delay.
Mark
Old 05-07-2020, 07:25 PM   #1360
reaper71
reaper71's Avatar
The battery will be housed inside the box in the bed.
This box was from a 29 model A sedan for luggage.
And I built a steel box that goes inside and locks.
Mark
Old 05-07-2020, 08:54 PM   #1361
joedoh
joedoh's Avatar
sueeeeeddde! looks great man!
its a nice update on the sander too, what will be the main usage?
Old 05-08-2020, 07:59 AM   #1362
reaper71
reaper71's Avatar
The usage of the belt sander is mainly for fabrication
Been wanting one for years,so I decided to just build one.
The reason for the paint....because I can
Mark
Old 05-08-2020, 09:51 AM   #1363
dsraven
hey reaper, what size of belt did you go with on the sander? looks good, and the width of the belt is wide enough to do some work for sure. nice.
Old 05-08-2020, 10:30 AM   #1364
Tempest67
Tempest67's Avatar
That headliner looks amazing....... thanks for the pics
Tempest67 is offline   Reply With Quote
Old 05-08-2020, 07:43 PM   #1365
reaper71
reaper71's Avatar
Thanks Guys!
The belt is 2" by 72" a fairly common size for belt sanders
Mark.
Old 05-11-2020, 11:15 AM   #1366
gigamanx
Pic 1. Primer
Mark
Ha, definitely won't go missing. Did you base it off plans or just started welding stuff together? What did you use for rollers?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 05-12-2020, 08:04 AM   #1367
reaper71
reaper71's Avatar
The main frame of the sander was based off the design from (Ameribrade) I used there wheels,platen and work table.
Then I modified the upper section as needed for the adjusting. I had No measurements,plans etc. when building this (I just winged it!) The stand was my design so it can be rolled around if needed.
Mark
Old 05-26-2020, 10:52 AM   #1368
reaper71
reaper71's Avatar
This not an update on my truck, however its some things I wantedto share.
Pic 1. The 55 I worked on awhile back has been gone for several months now.
Wanted to show what the metal work looked like.
Pic 2. This is Brendans diesel motor that will be going in his 67 truck.
The color is a Denali color from GM the truck will be painted the same.
Pic 3. Me and my Friend John were working over the weekend on his 48 Ford truck and this is the new flake.
Old 05-26-2020, 10:55 AM   #1369
8man
Wow! That really pops.
8man-aka Robert
Old 05-26-2020, 11:57 AM   #1370
OutlawDrifter
That flake is wild! My grandma had a '76 Beetle painted similar.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 05-26-2020, 03:33 PM   #1371
joedoh
joedoh's Avatar
wow that looks like a 70s glastron boat flake! really gorgeous!
Old 05-26-2020, 04:39 PM   #1372
OutlawDrifter
Russ, I had a '72 Glastron with a 455 Olds in "Root Beer Brown Metallic"...back in my younger wilder days.
1991 Z/28, 6.0L/T56
Old 05-26-2020, 07:38 PM   #1373
reaper71
reaper71's Avatar
Glad you guys liked it.
The interior is going to end up being done in pearl white should really Pop!!
Old 06-10-2020, 04:21 PM   #1374
reaper71
reaper71's Avatar
First time back on the ground in quite awhile!
Forgot how low she was !!
Old 06-10-2020, 04:38 PM   #1375
youngrodder
youngrodder's Avatar
It's funny how motivating it can be to see it on the ground.
Looks good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
