Old 08-06-2003, 10:10 AM   #1
ucmydust68
fuel
where can i get a rear disk kit for a 72 1/2ton
ucmydust68 is offline   Reply With Quote
Old 08-06-2003, 10:27 AM   #2
rin68
rin68's Avatar
i'll post some pics of the setup i'm using....it uses camaro front caliper--don't need a parking brake, caddy rotors, and a bracket i picked up on ebay. if you want/need an e-brake, rear calipers from a camaro or a caddy can be used. i'll get some pics tonight after work
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 08-06-2003, 12:10 PM   #3
ucmydust68
fuel
sweet thanks, i would need a parking break im running a six speed so i need that to stay still
Old 08-06-2003, 10:01 PM   #4
slam33
slam33's Avatar
rin68 I would like to see that too. I have the 77 Caddy Seville rear set up but the hats will not fit the axles unless I turn the hub down.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-08-2003, 04:01 PM   #5
rin68
rin68's Avatar
slam--I had to turn my axles to get the Caddy rotors to fit, the setup goes together well. hopefully performs well too. here are the pics.
Old 08-08-2003, 11:56 PM   #6
chiphayes
keep us posted,im curious to see if you have to changfe the proportioning valve,i want to do the same thing
chiphayes is offline   Reply With Quote
Old 08-09-2003, 02:35 AM   #7
GMCPaul
Thumbs up
We carry the rear disc kits, you'll find them here
http://www.gmcpauls.com/Brakes&Steering.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 08-09-2003, 07:00 AM   #8
chiphayes
paul i your the man, and the price looks good,i have power brakes,but will i need to change prop valve?and do you keep the disc kits in stock? if so i will come down and check them out
Old 08-09-2003, 09:18 AM   #9
slam33
slam33's Avatar
Are those the 10" or 12" disks and what disc application are you using ?
</A>
Old 08-10-2003, 12:12 PM   #10
rin68
rin68's Avatar
They're 12" discs, from a 77 Cadillac Sedan deVille. I'm using Classic Performance Products master cylinder/booster/prop valve setup, it's supposedly set up for 4whl discs already but i might have to add an adjustable valve. hopefully in the next 3 wks i'll be able to get all the parts on the truck i'll post results/performance when its up and running
Old 08-12-2003, 10:44 AM   #11
slam33
slam33's Avatar
Try the car and truck shop, they have a 4whl disc prop valve
</A>
Old 08-15-2003, 08:18 AM   #12
GMCPaul
Our rear disc kit comes with the 12" rotors in either 5bolt on 5" pattern or 6bolt on 5 1/2" pattern, and they use the Cadillac style calipers so you can connect the emergency brake and keep it functional, they also include all mounting brackets, hardware & hoses. Chip we try to always keep everything in stock, but it always pays to call in advance as our inventory is always going in and out the door. The prop valve should be changed to a disc/disc valve or a adju7stable prop valve should be added inline to adjust braking bias.
GMCPaul
Old 08-15-2003, 11:22 PM   #13
slam33
slam33's Avatar
The trick is to find the mounts by them selfs. the backing plates I have need to be redrilled to fit my axle housings.
GMC Paul, do your hats fit a standard hub or do I need to turn down the hub ?
</A>
Old 08-18-2003, 03:36 PM   #14
rin68
rin68's Avatar
the backing plates/brackets i used came from Steeltech Solutions in Marion, IL; i don't remeber the phone number but could probably dig it out if anyone is interested
Old 08-19-2003, 10:00 AM   #15
slam33
slam33's Avatar
Found this page on steel tech
http://www.oldcarguy.com/new_page_76.htm
</A>
