02-25-2004, 11:31 AM | #1 |
Burb not running right......HELP!!!
I have an 85 Burb. Had a Brand new crate motor and Edelbrock intake and carb installed a couple of weeks ago.
Heres the problem......after driving around for a while, when I get to a stop light it begins to run rough then dies...What can be the problem? Timing? Carb adjustment? Thanks in advance. |
02-25-2004, 02:07 PM | #2 |
Could be choke not turning off. Could also be idle mixture, have you adjusted it?
Brian |
02-25-2004, 02:30 PM | #3 |
Does it only happen when it's hot? If so, you may think about the fuel pump. Mine started acting funny with me when it would get hot before it went out.
Scott Shelbourne |
03-01-2004, 01:10 AM | #4 |
bpmcgee, it was the choke and the timing. Its running good so far. thanks for your help.
