07-03-2020, 10:53 PM | #1 |
hurst shifter recommendations
I want to buy new shifter and linkage for my m-20..... hurst comp plus ? my shifter is sloppy I have the bench seat shift handle for just need the shifter and new rods art #s anyone
thanks Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
07-04-2020, 01:35 AM | #2 |
Re: hurst shifter recommendations
If you have a Hurst you can buy all the rebuild parts directly from them. The rods most likely just need new bushings and some parts houses have them in stock.
If you have one of the cheaper "almost as good as the good Hurst shifters then I can see getting the good one.
07-04-2020, 05:30 AM | #3 |
You can Hurst shifters back to them and they will rebuild them. They did mine for free, but that was a long time ago.
07-04-2020, 07:48 AM | #4 |
im looking for a part # I don't want to re build I am considering buying new for this build shifter and linkage ...what have you used ?...free shipping summit part #
thanks
07-04-2020, 08:17 AM | #5 |
I bought my Competition plus shifter body/with GM truck/shifter handle directly from Hurst no tax free shipping . The installation kit /rods came from Hurst . I used the tool steel bushings and clips from 5speeds.com It's all pricey
gearboxvideo/ 5speeds.com install video - https://www.youtube.com/watch?v=_40q7wbeoRQ https://www.youtube.com/watch?v=yaQwPQTenMg Hurst Competition/Plus Installation Kits 373 7834 Hurst $211.95 https://www.holley.com/products/driv.../parts/3737834 Hurst competition plus shifter GM truck with Muncie 391 0002 $416.95 https://www.holley.com/products/driv.../parts/3910002 Holley has absorbed all these companies Tool steel bushings $19.95 5speeds.com
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-04-2020 at 08:31 AM. |
07-04-2020, 08:34 AM | #6 |
ahh... exactly what im looking for .....I was confused with all that hurst offers and summits choices thanks Grumpy do you have a side shot of your trans all tabs in neutral and what is your trans m-??
07-04-2020, 09:29 AM | #7 |
I had mine totally rebuilt using a (72) 661 main case with the 1" counter shaft and drilled and tapped for the fill/drain magnetic plugs from Paul and a number of other upgrades from his videos , I used the drivers side speedo tail shaft and even used the (Joe Gibbs) Driven gear oil in the trans and rear posi diff (locally $30.00 a quart Summit about $10.00) M-22 geared with the red speedo gear using 29" 255-70-15 tires should keep my speedometer correct .
https://www.youtube.com/watch?v=HUBFMwO8Qc0 https://www.youtube.com/watch?v=Z7NpsMZ9pBQ I watched all of Paul's gearboxvideo's on the Muncie's , I mean hey the guy wrote the book on Munice's and for what it all costs to use an old school 4 speed I'd rather only do it once ( I hope)
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-04-2020 at 09:37 AM. |
07-04-2020, 09:34 AM | #8 | |
Im truly impressed with your attention to detail I watched that video helped tremendously I been struggling with the shifter action for 2 days I think I can solve the problem ill let you know thanks again jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 07-04-2020 at 09:35 AM. Reason: more |
07-04-2020, 01:00 PM | #9 |
I have Paul's book, very good!!!
07-04-2020, 03:28 PM | #10 |
you have to have a set of TA 255 x 70 x 15 radials with Corvette chrome rallye wheels with spinners and a posi 12 bolt to go with your Muncie .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-05-2020, 07:46 AM | #11 |
im doing half of that ...I like yours.....but I like mine toooo... its that beauty ring & center cap look...and a 373 posi out back gets me reasonable highway rpms
