05-23-2006, 10:37 PM | #1 |
72 truck with a 454 from the factory?
Someone told me they know someone who got a 72 short bed with a 454 brand new. I always thought that 402 was the bigest that came in them till 73, so did any trucks come from the factory with a 454 in 72?
05-23-2006, 10:38 PM | #2 |
Re: 72 truck with a 454 from the factory?
maybe.............if you had the right connections they would build it.
My grandfather used to special order buicks with wild combo's. I don't see chevy being any different, COPO |
05-24-2006, 01:05 AM | #3 |
Just El Camino's and Sprint's. If a C-10 came with a 454, it would have to be some sort of COPO. I kind of doubt it, because I would think someone would have discovered one by now. Just like all those '67-'72 big block 4X4's that didn't come from the factory but everyone says are original. I say '73 was the first year for the 454 in a truck. And I have seen '73 C-10 shortbeds with 454's in them.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
05-24-2006, 01:41 AM | #4 |
71 GMC 454/TH400
The 454 was available in 71-72 GMC 3/4 ton only as an option, it was known as the "Invader 454" which was a 270 horse unit with oval ports and low rise cast Iron intake. The 454 was also available in the 3/4 ton vans as well. The 454 was not available in a chevy untill 73.
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
05-24-2006, 04:00 AM | #5 | |
05-24-2006, 11:52 AM | #6 |
I SURE WOULD LIKE TO SEE A PICTURE OF A GLOVEBOX OPTION SHEET THAT SHOWS A 454 CU IN ENGINE OPTION IN EITHER A GMC OR A CHEVY TRUCK IN 1972. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-24-2006, 05:00 PM | #7 | |
71 GMC 454/TH400
05-24-2006, 05:10 PM | #8 |
TOTY 2006
Wow, Lighten up farmtruck,
I agree with junkyardjohn, I would like to see the glovebox option sheet. I don't doubt that there was a chance to have a 454 in the GMC truck, just would be cool to see the sticker. That would be huge bragging rights in my opinion. |
05-24-2006, 05:44 PM | #9 |
The LuvShack Garage
Play nice kiddies, I too would like to see that on a glovebox sheet, I have
almost 50 option sheets saved, use them for research purposes, got pic's?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-24-2006, 06:52 PM | #10 |
Cantankerous Geezer
Lumber yard I worked at had a 427 in a 69 GMC tractor. Never heard of a 454, but that doesn't mean they didn't happen. That would be an interesting sheet of paper. Maybe someone could type one up.
Fred There is no such thing as too much cam...just not enough engine. |
05-24-2006, 08:45 PM | #11 |
its all about the +6 inches
Why would the VIN have an engine displacement code? C is V-8, E is Inline 6, and M is V-6... no displacement breakdown in the VIN.
I have never heard of a 454 being an RPO (regular production option) in 67 - 72 trucks, like the 400, it's just a common transplant. I have quite a bit of factory lit here (granted, mostly chevy) that says nothing about 454. I have a huge binder stuffed with dealer ship letters, from GMC corp to the dealer, notes about certian options being introduced mid year, options being discontinued, stuff like that, and just about evey engine is mentioned... except the V-6, and no mention of 454 anywhere.. It coulda happened, but I too want to see a SPID label, or factory, dated lit, saying something about it. I've heard ppl say "LMC has the stickers, so it musta been real".... not always the case. |
05-24-2006, 09:18 PM | #12 |
collector of vintage rust
Wasnt the 454 available in 70 in a few cars? Chevelle/impala? I suppose stranger things have happened...
05-24-2006, 09:39 PM | #13 |
ive got 71 GMC lit with all possible options for 1/2 and 3/4 ton 2wd trucks and listed as the biggest engine available for either was 402.
05-24-2006, 09:41 PM | #14 | |
71 GMC 454/TH400
Correction C=2 wheel drive, and E=V-8, and GMC had added codes for 71-72 they added the "T" designation for GMC only and they engine code option for GMC 2500 series and up. I will agree that the 454 was never available in the 1/2 ton, but it was available in the 2500 (in rare cases) but was mostly found in 3500 and up heavy duty trucks. The 454 was replaced by the tall deck motors in industrial apps in late 73. This is information out of a service manual given to me by my deceased great uncle. If I had a scanner I would provide the proper info.
05-24-2006, 10:15 PM | #15 |
good catch on the C... my fault.
Do you have a digi-cam? I'd like to see this. Not callin you a liar.. but i'd really like to see this for myself. Any chance in making a couple photo copys and dropping them in the mail for a nominal fee? |
05-24-2006, 10:32 PM | #16 |
71 GMC 454/TH400
No problem, I'll see if can can get them copied at work tomarrow.
05-24-2006, 10:47 PM | #17 |
My glovebox sticker shows a 396, I thought all the glovebox stickers would show the engine C.I.D.
I had thought that the big (tons and bigger)trucks got 427's, not 454's. But, its just "what I thought", so dont put much store by it.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
05-24-2006, 10:52 PM | #18 |
glove box sticker (option sheet, spid label) DOES show CID if it is an optional engine. So the 250, wouldn't be listed on a S truck, a 307 or 283 wouldn't be listed on a E truck, and a 305 wouldn't be listed on an M truck.
The one ton wasn't avalible with the tall deck 427, nor the tall deck 366, but on the C/40 and up, they were avalible. |
05-24-2006, 11:04 PM | #19 |
71 GMC 454/TH400
The book I have only covers GMC, and it shows the tall deck unavailable untill late 73.............
05-25-2006, 04:48 AM | #20 |
Tall deck Mark IV 366 and 427 big blocks came out in the mid-60's Chevy C-60 and larger trucks. They had 4 ring pistons and until '70 had reverse rotation gear drive cams. A few tall deck 454's were built in '79-'81 or so, again for medium duty commercial trucks. The 'Invader 454' was a regular option in '71 and later GMC Sprints (a somewhat rare El Camino clone), if you were wondering where LMC got that valve cover decal from. But as for a 454 in a '71 or '72 C-10/20/30, I have never seen one, nor have I ever seen any Chevy or GMC literature listing the 454 as an option in those trucks. That's not to say it wasn't some COPO or SEO, or maybe some dealer option. I saw a '65 C-10 with a 409 in it, and the owner had documentation that it was a authorized dealer installed option.
05-25-2006, 06:03 AM | #21 |
i wonder if gm was screwing around with them like they did with cars. In my local chevy dealership back in 1969 they unloaded 4 really weird camaro's that i've never seen or listed. One was a black ss/427. The whole interior was bright yellow. never seen one since. one z28 was a wierd green with equally wierd looking green stripes. I've never seen the colors listed or seen any others.
05-25-2006, 08:08 AM | #22 | |
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
05-25-2006, 08:38 AM | #23 |
tThat would be Dealers screwing with us,not factory.Like Yenko or,more recently,SLP who bought cars from the factory and dropped their own powerplants in,one car/two motors/expensive.
The "T" prefix on GMCs and additional "C" on the VIN was started in`72 to distinguish GMC from Chevy.Up until then you couldn`t tell a Chevy from a GMC by the VIN.The "T" has nothing to do with engines.It`s "S" for 6cyl,"E" for V8,and "M" for GMC V6.As said already,that is a "cast in stone" number that stays with the vehicle no matter what gets changed,but is no more specific than configuration.Base motors within these configurations are not listed on the VIN-spec sheet because they are not options.I have been around these trucks since they were new,know alot,and love to learn what I never knew,still.GM was naming the 454 truck motor "Invader".Not saying this info came from LMC,but I see the "All Wheel Drive" front fender emblems that only came on 69/70s listed in numerous catalogues as 67-72,just to make an example.They`re not encyclopedias,they are catalogs to sell things,correct or not.I would like to see proof of the 454 coming from "factory" in any GMC light truck. Going back to the thread starter about the factory 454 shortbed,I wonder what proof this guy has.Alot of smoke out there,don`t inhale if you`re not sure what it is.
05-25-2006, 09:44 AM | #24 | |
05-25-2006, 09:55 AM | #25 |
Just wanted to throw some data I found in my original 1972 passenger cars and 10-30 series trucks OVERHAUL MANUAL.
I found this in the carburetor ID charts... The 454, RPO LS-5, available in the Chevelle, Monte Carlo, Caprice, Impala, Belair, Biscayne, and Corvette. I didn't know the 454 could be had in all the cars except Vega??? The 427, RPO L-43, C60 and S60 trucks only. The 366, Base in C60 & M60, RPO L-86 in C50 & S50, which I believe is a tall deck BB. Interesting info. What the heck were the M and S series trucks?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 05-25-2006 at 10:00 AM. |
