08-15-2018, 09:58 AM | #301 |
Re: LS factory cruise control hook up
Hey man ... tried to reply to your last PM but it states your inbox is full.
thanks! |
03-18-2019, 07:45 AM | #302 | |
lsnova71 I know it's been a while since you offered to the group, but I'd like to get on the waiting list for one of your refurbished cruise turn signal levers. I hate how the aftermarket switches are backwards. This is my first forum membership thru all the years of web crawling. Thank you to everyone for sharing their knowledge...without you many of our projects wouldn't be. Cheers! |
05-08-2019, 09:46 AM | #303 |
pm sent
05-11-2019, 11:07 PM | #304 |
Ahhhmaazziinngggg! Thanks guys!
05-27-2019, 02:37 PM | #305 |
Thanks to the volumes of information in this thread, I'm almost there to cruise control! Wiring is done and checks out. I have an s10 steering column that doesn't send power to the C terminal when the RA button is pushed....so I ordered a new cruise control switch. I believe when I have this fixed I still won't have working cruise because I have LED taillights.
LS1NOVA71 has said that putting an 1157 bulb off the brake switch should give the resistance I need to overcome this. My question is, what does it take for a resistor to do this same thing. Common 6ohm 50 watt resistors they sell for LED's advertise as getting very hot. I'd rather not have something under the dash that gets hot like this but will if that's my best option. Are there other options? Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
05-28-2019, 08:21 AM | #306 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-30-2019, 07:38 PM | #307 |
Thanks! I like that idea a lot better. I'll do that this weekend and report back.
06-01-2019, 12:41 PM | #308 |
I picked up a new cruise control switch this week and a micro relay and holder. Got the switch replaced and everything now tested out good. Then installed the relay (just the coil) and now my cruise works!
Thanks for all the info in this thread! My 16 hour drive on Friday to the start of the Hot Rod Power Tour will be so much more enjoyable this year.
06-01-2019, 01:35 PM | #309 | |
Old member
BlueJeep;8535108 if you need anything when you get close to Charlotte hollar at me. Your welcome to run with us if you like also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-01-2019, 06:10 PM | #310 | ||
06-01-2019, 06:28 PM | #311 | |
Old member
I hope we can meet up I'd like to thank you for the help on the cruise.
06-01-2019, 07:21 PM | #312 | ||
I'll be in this:
06-13-2019, 10:37 PM | #313 |
awesome thread, subbed for sure
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
06-19-2019, 09:38 AM | #314 |
Old member
It was sure nice finally meeting you ls1nova71. The cruise worked great. The truck ran fine all week.
BlueJeep sorry we never got together. I passed you on the 4 lanes coming out of the Cumberland Gap tunnel though.
06-20-2019, 11:42 PM | #315 |
Nice meeting you too Andy, its cool to be able to put a face to a name! Also met NC_John, BlueJeep, and dayj1 on the tour, it was definitely the place to meet people.
06-21-2019, 10:35 PM | #316 |
Old member
Yes it is for sure. I would like to see some more of the ride you where in on the tour. That thing was nice.
06-26-2019, 03:49 PM | #317 |
Any chance you have any more switches?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-04-2020, 08:05 PM | #318 | |
So cruise control(dbw or cable box), LED lights, and a relay. What ls1nova71 means exactly here is that you take the brake switch wire(from the inside of cab, white wire off switch) or either left or right brake light wire outside of cab, and splice into that, one end of the wire attached to relay 85 pin, the other end of the wire attached to relay 86 pin. You DO NOT GROUND the relay. You are only using the relay coil inside the relay like it's a "resistor". Someone like me who needed that detail, might benefit from this post. EDIT: See posts below, I was wrong.... .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 03-06-2020 at 01:45 PM. |
03-06-2020, 03:24 AM | #319 | |
03-06-2020, 01:41 PM | #320 |
Oh, so you DO ground the other side of the relay? Ok, that is how I have it now and I thought I had it wrong after re-reading your post and the wording you used. I'm no wiring expert so I sometime need things explained to me like I am a 3 yr old....
I have the American Autowire harness so I used the 3rd brake light wire(blue) that is tapped into the white wire already on the brake switch connections. .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
11-23-2020, 07:39 PM | #321 |
chevy truck fan
I am currently in the middle of a 2013 LS truck swap into a '86 C10. I am trying to connect the TCC wires between the 2 trucks. I have the 2 (lt blue/wht stripe) wires ID... both come from the same pin at the '13 ECM. I have ID the lt. blue wire & brown/wht stripe wire from the '86 switch (in cab). The '86 lt blue wire comes thru the firewall with a green wire both end at a connector, the green wire then runs single to a connector (byself). looking for help with how/what to connect at what point(s)? any assistance would be greatly appreciated .... thank you again!
11-23-2020, 11:29 PM | #322 | |
11-24-2020, 02:21 PM | #323 |
chevy truck fan
ls1nova71, THANK YOU!!for the reply... I guess (then if I understand) the lt blue wire from the '86 (coming out from Firewall) is the hot wire when brakes APPLIED then I can connect 1 of the '13 lt blue wire to it? also what do I do with the 2nd lt blue wire from the same pin from the '13 ECM? for some reason the '13 "X conn." at the mounted factory underhood fuse box has 2 small ga. lt blue wires coming from the same pin, this is what is confusing me... I don't understand the purpose of 2 wires splitting at the factory connector - if the wires do different things... i am having a hard time with deciphering the '13 wire diagram
I appreciate your patience I am far from a electrical guy.. so I apologize for my dumb questions I can tell by your builds that you are very knowledgable and talented builder |
11-24-2020, 07:40 PM | #324 |
Thanks for the compliments, sounds like you are on the right track. As for the second wire coming from the ECM, without looking at a schematic its hard to know for sure what it went to, but it was something on 2013 truck, something your swap doesn't have, so you can just cut the remaining wire out or tape it up good so it doesn't short out against anything.
11-28-2020, 01:42 PM | #325 |
chevy truck fan
LS1nova71, THANK YOU!! I am going to wire test this weekend & then finish that particular connection. My next big hurdle is the grey fuel pump pwr wire ('13 ecm) to go ??? with the factory dual tanks from the '86!
I really appreciate your time in answering questions!! the board is still good to have for me being an 'ol skool guy W/O FB or IG ... |
