Old 11-05-2017, 12:28 PM   #151
OKGMC4
OKGMC4's Avatar
Re: Mr Green Jeans - the 69 (or not) chevy, er gmc, project
Originally Posted by swamp rat View Post
You have been doing some amazing work!
Originally Posted by IRQVET View Post
I was thinking the same. Its one thing for a professional mechanic/ fabricator to build something cool, but a regular guy DIY build is something to behold.
Thanks for the support. It helps keep me motivated. Sometimes that’s harder than the actual work!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 11-05-2017, 12:31 PM   #152
OKGMC4
OKGMC4's Avatar
Since knomadd got HIS Dapper lighting headlights in I decided to dust mine off for a trial fit. Plus I’m thinking the bulbs may affect my air box construction since they stick through the core support.
Old 11-05-2017, 12:33 PM   #153
OKGMC4
OKGMC4's Avatar
White or amber halo rings.
Old 11-05-2017, 04:49 PM   #154
Chumly223
Chumly223's Avatar
tailgate is killer
keep up the good work
Chumly223 is offline   Reply With Quote
Old 11-06-2017, 09:53 AM   #155
knomadd
knomadd's Avatar
Damn, those lights look good! I like the white halos myself, but either would look good. Do they work as turn signals too?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-06-2017, 10:24 AM   #156
OKGMC4
OKGMC4's Avatar
I bet they could. I didnt buy the optional controller. As they are, there are only three wires. A common ground wire, red line in for white, and yellow line to amber. Haven’t decided if I want to use the amber or not. When I ordered mine they were out of white only and Jonathan at Dapper offered me an upgrade so they could be built faster.
Old 11-07-2017, 05:17 PM   #157
knomadd
knomadd's Avatar
That's cool. I didn't know that was an option when I ordered mine. I have a set of their 575s for my GTO. I didn't go with any halos though. I have them on my V2s for the 71, but I haven't hooked up the halos yet.
-Duane
Old 11-07-2017, 09:14 PM   #158
OKGMC4
OKGMC4's Avatar
A box of random goodies showed up today.
Old 11-07-2017, 09:17 PM   #159
OKGMC4
OKGMC4's Avatar
...and the next painstakingly slow project starts.
Old 11-08-2017, 04:47 PM   #160
knomadd
knomadd's Avatar
Is your MAF sensor a clamp on style that will fit between tubes, or do you have the card style? If it's the card style, how are you adding that?
-Duane
Old 11-09-2017, 04:29 AM   #161
OKGMC4
OKGMC4's Avatar
Clamp on. It will push through the back of the enclosure I'm trying to build, and it has three little holes on the flange that I can put bolts through to attach it. I just can't figure out how to make it look good AND be functional.
Old 11-10-2017, 05:50 PM   #162
knomadd
knomadd's Avatar
Well darn. I was hoping you had the card style like I do so I could steal your idea. It'll look good when you're done.
-Duane
Old 11-10-2017, 06:34 PM   #163
OKGMC4
OKGMC4's Avatar
I "think" Spectre makes an aluminum adapter for those style MAF sensors.
Old 11-10-2017, 06:58 PM   #164
knomadd
knomadd's Avatar
They do, but it's aluminum. I don't have the welding equipment or knowledge to weld aluminum. I can do stainless just fine. If I could find a stainless weld-in adapter, I'd be set.
-Duane
Old 11-11-2017, 10:22 AM   #165
OKGMC4
OKGMC4's Avatar
That’s why I’m doing my intake in steel. I know it’s heavier but it’s what I know I can work with. My father in law is a machinist. I bet if he had a MAF pattern he could make an adapter plate to be welded onto the pipe. I wonder if there’s an eBay market for that?
Old 11-12-2017, 10:28 PM   #166
OKGMC4
OKGMC4's Avatar
I is dumb. Was about half done with the pipe when I realized the MAF would be pulling in air 90 degrees to itself. With a little reworking I moved it downstream into a straighter section of pipe. Should help it read airflow better. Now I can work on finishing the filter box.
Old 11-26-2017, 05:36 PM   #167
OKGMC4
OKGMC4's Avatar
I wanted the air box to kinda sorta match the engine covers so I built it with the same perforated stainless steel theme. I’ll paint the metal underneath black and the air box will probably be body color.
Old 11-26-2017, 05:43 PM   #168
flashed
That looks great.
flashed is offline   Reply With Quote
Old 11-27-2017, 09:11 AM   #169
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by flashed View Post
that looks great.
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-28-2017, 11:50 PM   #170
Russell Ashley
Russell Ashley's Avatar
Cool build. Wish I'd have found it sooner. I've never seen a uni-body GM truck before.
Russell Ashley is offline   Reply With Quote
Old 01-21-2018, 08:08 PM   #171
OKGMC4
OKGMC4's Avatar
I have spent a ton of time pondering mirrors. I could go on about the ones I don’t like, or are too big, or just won’t fit the door, or cost too damn much, etc. instead I will just say I have settled on the reproduction raydot mirrors found on ac cobra kit cars and vintage 60’s race cars such as Shelby mustangs and all of the old school British roadsters. I think they are a good balance of fit vs cost vs good looks. Hope you guys like them..
Old 01-21-2018, 10:50 PM   #172
Ol Blue K20
I like them, they fit and look nice..
Dale
Old 02-18-2018, 11:08 AM   #173
RCbowtie69
RCbowtie69's Avatar
Looking good,keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 06-01-2018, 08:36 PM   #174
G&R's57GMC
G&R's57GMC's Avatar
OK , its time for an update ... What's UP ?
This is a great project and we want to see more !
As for the mirrors they look good on there . I like the fab work.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 06-01-2018, 09:05 PM   #175
Ol Blue K20
What he said ^ x2
Dale
