04-07-2007, 05:07 PM | #1 |
How does the brake light swith hook up and work??
im a rookie...thanks for the help
04-07-2007, 06:26 PM | #2 |
Re: How does the brake light swith hook up and work??
just bumpin
04-07-2007, 06:58 PM | #3 |
heres the switch just mounts to a bracket under the dash and bumps into the brake pedal.
very simple little switch.. heres a picture Last edited by rage'nrat638; 07-12-2007 at 06:54 AM. |
04-07-2007, 07:36 PM | #4 |
so where does it just hooks up one for the power one for the ground or what??
04-07-2007, 08:10 PM | #5 |
Dave's not here, man
There is a plug for it above the brake pedal. Should be plastic; it plugs into the bottom of the switch and snaps in place.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 04-07-2007 at 08:26 PM. |
04-07-2007, 08:25 PM | #6 |
Here is a pic. The brake pedal rod is in the way, but hopefully you get the general idea. Hope this helps.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
04-07-2007, 08:27 PM | #7 |
sufficiently talented fool
One of the wires is a power wire, the other goes to the brakelights.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
04-07-2007, 08:32 PM | #8 |
well im off to see if it works...if the signal works the brake lights should work too eh?
04-07-2007, 08:36 PM | #9 |
No. The signals could work and you could still have no brakelights. The wire that goes to the brakelights goes thru the turn signal switch. Check for power on the one wire at the switch. Then check the other. It should have power only with the pedal depressed. If they are OK, then you need to check the turn signal switch.
04-07-2007, 08:55 PM | #10 |
yeah the lights dont work i plugged in orange to orange wires and white to white and it aint workin...
04-08-2007, 02:11 AM | #11 |
well it turns out there was no power to the line which goes underneath the floormat which surprised me...anyone now there these wires are supposed to go?? like from the switch?
