06-07-2014, 03:45 PM | #1 |
Re: Is this cab mount correct?
'68 C10 SWB '85 K30 Blazer |
06-07-2014, 04:02 PM | #2 |
Here's a picture of mine (3/4 ton). As I said above, I ended using the 67/68 kit since that's the type mine had from the factory. However, my originals had larger washers (probably due to larger holes in the 69 brackets) so I used the washers from the originals. I also couldn't get good gaps between the fenders and cab with the 69-72 core support mounting kit.
