05-12-2020, 01:26 PM | #1 |
Steering cover panel bolt size and seal?
I cant find the bolts but the picture I took as I removed it show all 5 of them on the floor. I was going to get stainless this time and was looking for the size of the bolt. Anyone know it? Also the seal, is it the same as an inner fender seal?
05-12-2020, 02:28 PM | #2 |
Moderator
Re: Steering cover panel bolt size and seal?
They gotta be 1/4"-20, check and see.
If they are - https://www.ebay.com/itm/10-pc-1-4-2...IAAOSwB51c1uua
05-12-2020, 04:05 PM | #3 |
I think the seal is the same as the inner fender seal. If i remember correctly the inner fender seal is one long piece and you cut that portion out to use on that piece.
05-13-2020, 02:38 PM | #4 | |
Thanks, I'll give it a try with the fender seal I have. Gott get some stainless staples now. |
05-13-2020, 03:26 PM | #5 |
I might be wrong but I think there are 2 bolt sizes needed for that panel.
05-13-2020, 04:05 PM | #6 |
Moderator
Ya, you may be right come to think about it.
msg - You dont have a nut/bolt/screw gauge? They sell em at home depot, Harbor freight etc. Without one you may be doomed in the future. As an example: https://www.ebay.com/i/382885571968?...RoCfSgQAvD_BwE
05-13-2020, 05:39 PM | #7 |
I will make the investment. I found a bolt in the baggie of glove box parts that threads through the top 2 of the inner fender but not the lower 3 of the assembly plate. The bolt I used was the one that the glove box pivots on.
05-31-2020, 01:30 PM | #8 |
Moderator
On page 109 of the yellow assembly manual it shows part #3759038 for the screws.
In the GM parts wiki for our truck it shows 3759038 is a 1/4"-20 X 5/8" http://www.gmpartswiki.com/getpage?pageid=26591
05-31-2020, 02:26 PM | #9 |
I just did mine they are all the same size but sum how I Managed to lose one Lol
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent Last edited by nsb29; 05-31-2020 at 07:53 PM. |
06-04-2020, 10:27 AM | #10 | |
https://www.homedepot.com/p/8-11-16-...O-02/100186831 I obviously do the same thing. These parts as hard as I try to keep together they sometimes get away. By the way I hope to soon be ordering one of your AC vent boxes soon. Theres so much going on. I may begin first with the ammeter to voltmeter conversion like you and others have done. |
08-12-2020, 08:53 PM | #11 |
MSG--did you ever replace these bolts? What size did you use?
EDIT: Nevermind...found them...it is 1/4"x20...didn't look like that to me though...but they are perfect! Last edited by roll_the_dice; 08-13-2020 at 12:05 PM. |
08-14-2020, 08:44 AM | #12 |
Glad you can vouch for the fit, I still haven't gotten to the reassembly. So looking forward to it.
