01-05-2015, 07:56 PM | #1 |
1980 k5 blazer 2wd conversion
Hi everyone. I started this project back around April. I had a k5 tub, a 4x4 frame and a c10 parts truck. I looked for a 2wd k5 but here in Michigan they are far and few between. So I decide that I would make my own. I did a lot of research before I started and still am. This is a slow steady project. I'm aiming for 2 years to have a running moving k5. Hopefully it will be DD able. Right now I have all the big things.
1980 k5 tub $150 4x4 k5 frame $0 Parts c10 $100 2 Full quater panels $150 Vortec 5.3 $500 4l60e $150 Front end parts $100 |
01-05-2015, 08:05 PM | #2 |
Re: 1980 k5 blazer 2wd conversion
This was after 40+ rivets removed. Got all the 4x4 stuff out
01-05-2015, 08:12 PM | #3 |
This is the parts truck that I pulled the rear suspension, axle, front suspension and front clip.
01-05-2015, 08:15 PM | #4 |
After about 2 solid days of measuring I got the front and rear suspension in.
01-05-2015, 08:28 PM | #5 |
Flipped the rear axle and painted the back half of the frame.
01-05-2015, 08:30 PM | #6 |
I blocked up the body by myself to roll the frame under
01-05-2015, 08:32 PM | #7 |
Finally got the body on the frame. Now I'm ready to strip the interior to get the replacement floors in.
01-05-2015, 09:35 PM | #8 |
Im in to see the rest .
01-05-2015, 10:35 PM | #9 |
Wow, great job! You may beat your 2 year deadline at this rate.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-05-2015, 10:49 PM | #10 |
Thanks, right now I'm just trying to get the cheap stuff done. All my money is going into my first turbo hayabusa build right now.
01-05-2015, 11:15 PM | #11 |
Cool to see someone frim mid-MI as I was born and raised in Bay City. Are you looking for a lowered 2wd Blazer or close to stock height? I ask because it lookes like you used the 4x4 rear hangers/springs which won't net much drop even with the flip.
01-06-2015, 03:53 AM | #12 |
Don't forget that the 4x4 front spring mounts are actually different than the 2wd mounts. I'm actually in the process of swapping frames right now because my 2wd one is bent and I found a 4wd one to replace it with. The bottom of the front 2wd spring mount is even with the bottom of the frame and the 4wd one is lower than the frame rails.
01-06-2015, 07:01 AM | #13 |
I'm want it lowered but not slammed right now. The 56 inch spring pack is out of the c10. The hangers are 4x4 ones but used those just because they were on the shelf ready to go. I want to get the motor/transmission and front clip on. Then play with ride height from there. Thanks for the heads up on the spring hanger. I didn't know the front one was different.
01-06-2015, 09:51 AM | #14 |
78K & 79C Jimmys
cool ,getting some of the big stuff done right away
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-06-2015, 11:22 AM | #15 |
I know the pieces fit
Welcome to the site! That's one hell of a good start, nice progress.
01-06-2015, 12:03 PM | #16 |
Thanks everyone. This stuff I find easier. The hard part will be all the body work and breaking done the engine harness myself. This will be my first crack at serious bodywork. Busier can you post some pictures of your 2wd blazer?
01-11-2015, 02:36 PM | #17 |
So I started ripping the interior out of the blazer. The rust is worse than I thought. The floor, rockers and quarters are rusted bad. The whole side is sagging at least 1/2 inch. Does anyone know where I can find the correct dimensions so I can start rebuilding this.
01-11-2015, 09:53 PM | #18 | ||
01-11-2015, 11:03 PM | #19 |
Picture of the rocker
01-11-2015, 11:05 PM | #20 |
The inside corner that always rusts
01-14-2015, 12:38 PM | #21 |
I haven't fixed rust like that but check out russgt's thread on his 76, he made similar repairs on his truck.
05-20-2015, 04:16 PM | #22 |
very nice so far
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
06-25-2015, 04:17 PM | #23 |
any updates?
09-01-2015, 09:21 AM | #24 |
Any updates ?
