08-31-2021, 09:45 PM | #1 |
Active Member
Manual to Auto Tranny Crossmember Question
I am swapping from the original 3-speed manual to a 700R4 automatic. Is there any way to use the existing manual crossmember for the swap? I know this original sits further up the frame and there may be some angle/ alignment issues with moving it further back. I've already pulled it off the frame and restored it. Or maybe I just put the original on the shelf and buy one of those tubular crossmembers from POL or CPP. Thoughts??
08-31-2021, 11:52 PM | #2 |
Re: Manual to Auto Tranny Crossmember Question
I would measure the frame rails and see it they are the same height that far back. I believe you could use it if it fits. Might be low but a spacer would take care of that. The down side would be exhaust clearance and road clearance. Especially if it's a lowered truck.
A couple options if you decide to purchase one; https://www.ebay.com/sch/i.html?_fro...er&_sacat=6028 https://www.ebay.com/itm/40296240820...oAAOSwWj9g1Jbu |
09-01-2021, 07:24 AM | #3 |
Far as I remember the manual 3-speed (and I believe the 4 speeds) had no trans cross member. The bell housing was the rearmost cross member. But with the one pictured, you should just have to slide it back, drill new holes in frame and it is good.
09-01-2021, 08:25 AM | #4 |
If the cross member you have is a stock V8 manual trans truck there's no way it will slide back in the frame to use a auto trans , It won't fit due to the angle of the brackets to the frame and a auto trans rear mount would be at an angle . here's a pic of a auto cross member , You can see the difference .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-01-2021, 08:35 AM | #5 |
Active Member
Yes mine is a stock v8 truck. Thanks for posting the photo of the original auto crossmember. I’ll have to locate one or buy one of the aftermarket versions.
09-01-2021, 09:04 AM | #6 |
Another option is the 73 ^ auto trans cross member , Probably easier to find and a pretty easy bolt in . Also they have a higher exhaust clearance to keep the pipes tucked . I used one of these as a rear mount cross member for my 4 speed trans after a little modification .
09-01-2021, 09:07 AM | #7 |
I have one if you think you will be needing one.
09-01-2021, 01:31 PM | #8 | |
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
09-01-2021, 01:56 PM | #9 |
A Muncie M-22 using a drivers side speedometer tail case , With a Hurst Competition plus shifter . Hurst makes a shifter just for the Muncie conversion to fit our trucks
