06-01-2015, 04:40 PM | #176 |
Re: 1971 GMC SWB "No Direction" LS build
Great looking wheels!!!!!
06-01-2015, 09:04 PM | #177 |
Thank you! They're fairly common on these trucks but I couldn't pass them up. Should hold me over until I can get my dream wheels.
I was surprised to learn they're made in the USA. That's pretty cool!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
06-01-2015, 10:58 PM | #178 |
Robbie ,Im in Kokomo Indiana until tomorrow morning ,having a blast .We have seen several old trucks along the way that looked abandoned but in pretty nice condition ,wish we could have stopped and checked them out.We will be in Michigan tomorrow to go to the Henry Ford Museum and then to Frankenmouth for the night. Chuck has a lot planned for us to see.
06-02-2015, 09:19 AM | #179 | |
06-02-2015, 06:20 PM | #180 |
Robbie ,we are now in Canton/Ann Arbor Michigan and will go to the Henry Ford Museum tomorrow and we also hope to meet up with some friends up here as well.We finally got to drop the top on the Malibu today ,perfect day and place for cruisin. I never knew how nice Indiana and Michigan were before .The backroads Chuck picked out for us are great .
06-03-2015, 09:35 AM | #181 | |
06-03-2015, 09:49 AM | #182 |
So I know this issue has been beat to death on this forum but I tried to fit my Boss 338 20x8.5 with O-Ring caps (newer version) on the front of my 1.25" rotors and, exactly what everybody on this forum would expect, it needs some very minor grinding of the rotor hub. And likely some minor dimpling of the dust cap.
Not mad about it since I knew about this issue when I bought them. They actually ALMOST seat properly but not quite. Out comes the grinder! I've also been getting in a host of parts from Summit. I'm planning to re-run my fuel system this weekend and maybe even get started on the drop. Details below on it: - 3" Belltech drop spindles - 1" CPP coil - 3" CPP coil in the rear - 2" Way2lo2 blocks - CPP adjustable trac bar - CPP shock relocators - KYB shocks
06-03-2015, 01:05 PM | #183 |
Glad you can make the wheels fit. They do look good. Looking forward to drop updates. Good list of parts.
06-04-2015, 09:09 AM | #184 |
Thanks, AD!
06-05-2015, 11:37 AM | #185 |
I'm really reconsidering just keeping my stock tank now. lol i did just order an assortment of russell fittings needed. any suggestions for a place to clean and coat the tank? mine has a bunch of surface rust n **** inside -_-
06-05-2015, 12:09 PM | #186 |
There are probably more that a few places around town that can hot tank it for you and as long as there isn't any bad rust on the inside you don't even need to coat it after.
06-05-2015, 12:10 PM | #187 | |
Thankfully, the one in my current truck is clean as a whistle.
06-05-2015, 12:10 PM | #188 |
havent looked lately. wasnt like rotted...just surface type rust from sitting and being empty...def some debris floatin around in the bottom. ill search around.
06-05-2015, 01:45 PM | #189 |
Prestige Worldwide
Awesome score on the wheels Robbie!! I cant wait to get over your way here soon and help get this girls altitude adjusted....
06-05-2015, 01:47 PM | #190 |
Prestige Worldwide
If your tank is bad let me know, I have two that are both really clean and you are welcome to one if you can use it since I am never going to do anything with them.
06-05-2015, 09:36 PM | #191 |
Thanks, Jason! I'm looking forward to it, too. Planning to get a few things started tomorrow.
06-05-2015, 10:01 PM | #192 |
PICTURES ,PICTURES ,PICTURES or it didnt happen.
06-06-2015, 09:52 PM | #193 |
Well since you asked.....
It was a super productive day but once I got out to the garage and started looking at everything I'd bought for the fuel system and how I was going to make it work, I decided I needed to try something different. Basically, the whole system was contingent upon me having the correct adapter fitting for the hard line out of the tank to a -6 AN end. Well, the line out of my tank was 5/16 and I had bought a 3/8 adapter fitting. Also, the fuel feed line from the carb I was going to use wasn't going to be delivered until the 21st. All that said, I grabbed a piece of paper and my laptop and figured out an even better solution than all the PTFE line and super expensive fittings. Here's what I ended up going with: 3/8 aluminum hard line Russell banjo carb to -6 AN fitting Various Russell 3/8 to -6 AN adapters Russell Pro Classic II braided hose Russell fuel filter Holley Red pump Earl's 5/16 hard line adapter to -6 AN fitting So, once I got that I started constructing a few hoses and connected the banjo fitting to the carb; fitting to the hard line out of the tank; and fittings to fuel pump. I'm one hose end short and am likely going to run another fuel filter before the carb but it's progress. Need to get a tube bender, too. Since flashed asked, here's a few pics. I also got my PCV valve and lug nuts while I was at Summit. Anyway, pics....
06-06-2015, 10:21 PM | #194 |
Is that all ? LOL
06-06-2015, 10:43 PM | #195 |
John, you are killing me! Lol
I was a one man team, didn't even get out to the garage until 11 am, cleaned up the garage, then had a 3 hour roundtrip to Summit after I spent about an hour researching new parts and finding receipts for the current stuff. Considering all that, it was a productive day. It's amazing how much time I spend looking at stuff trying to figure out the best possible route/way to do it.
06-06-2015, 10:48 PM | #196 |
Great ideas on the plumbing. Yep, it always seems to take way more time figuring out parts and sources than putting something together. A good day.
06-06-2015, 10:52 PM | #197 |
Its easy for me to give you a hard time since mine is done (sorta) ,buts its all in good fun .Im just a little bored right now sitting in a hotel room far from home busting your chops but you are actually accomplishing something with your truck and 2 of mine are at the bodyshop .The 1 ton is just waiting for something to happen and the red truck I hope is getting dual electric fans installed .At least you are working on your own truck as I hire someone to do mine while Im out playing .I look forward to seeing you and your truck cruising around .
06-07-2015, 11:40 AM | #198 | |
Can't wait to hear all about your trip!
06-10-2015, 04:18 PM | #199 |
06-13-2015, 09:10 PM | #200 |
Made another trip to Summit, got more of the fuel system put together and Number98 came by and helped me knock out the front drop (3" spindles, 1" coil). Next up finishing up the fuel system, dropping the rear, and getting the exhaust put together. Another set of TBSS manifolds (w/collectors) are on the way as well. Should be here next week.
No pics since I'm getting new rotors and don't have the wheels on yet. Not a bad Saturday at all. Also, goes to show you how awesome this board and it's members are. Thanks again, Number98.
