11-06-2015, 06:48 PM | #376 | |
Simple? What's simple?
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
As far as the radiator goes - you could do what I did - I mounted a stock style radiator to the front of the core support, instead of to the rear - that bought me about 2.5" of space, so I was able to squeeze a fan in there without modifying the firewall. The front of the core support isn't flat, it has a flanged edge, you can use washers or a piece of bar stock to space it forward just enough to clear the flange. I'm running a high flow 16" fan, about 3-7/8" depth.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
11-06-2015, 06:55 PM | #377 |
Also picked up a Camaro oil pan. Don't have it in the shop as it's at my US shipping address. Just have to go and get it. It's a brand new F-body oil pan (GM p/n - 12628771) It comes with the pan, oil pan gasket, baffle, pick-up tube, and oil pump o-ring. $215 US shipped. Close to $300 Canadian but our dollar sucks right now.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
11-06-2015, 07:21 PM | #378 |
Thanks for the info JJorgensen52. I will check out your build and see how you did things. What you did with the rad would save a bunch of work and money. Looking at vette front accessories to try and pull things closer the block. Your way may save me!
11-06-2015, 07:31 PM | #379 |
Sid your exhaust manifolds look good. I will keep that idea in mind for mine. Hats off to you guys that modify the stock harness.
11-06-2015, 07:49 PM | #380 |
Thanks AD. All I have in that harness and PCM and the other stuff is $150 so it's worth a try to modify it. Actually now that I think about it, I got all that and pwr steering pump, engine cover and flywheel for that price. I plan on attempting to modify the stock harness but we will see once I get into it. Old wires, connectors and such.
11-06-2015, 07:52 PM | #381 |
Another question. I have no idea on brake boosters or hydro boost or any of that stuff. How do I go about choosing one? I don't mind a chrome booster under the hood. Spill it guy's! I'm really dumb on that subject. Gotta have an idea on what I want to do so I can plan out the firewall.
Cheers!
11-06-2015, 10:40 PM | #382 | |
Here's a link showing my radiator, then there's a few shots showing fan clearance on the accessories as well: http://67-72chevytrucks.com/vboard/s...&postcount=315 http://67-72chevytrucks.com/vboard/s...&postcount=317 And this is by no means an original, I stuck with the S10 booster setup many others have used (credit to skymangs for the original FAQ on this one): http://67-72chevytrucks.com/vboard/s...&postcount=166 1st gen S10 booster and pedal bracket assembly - I used the big, 11" dual diaphragm booster for my mockup. I'm considering swapping down to the 9" dual diaphragm that the first gens used, but: I have a friend, older gentleman, who has been building racecars and doing restomods for a living for YEARS - he's had a bunch of bad experiences with customers bringing in cars with compact, universal Hot Rod boosters that just weren't up to snuff for stopping a car with discs and so on. So I designed around being able to use the 11" booster, which is what the 2nd gen S10 uses (and that's what my brakes are).
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 11-06-2015 at 10:47 PM. |
11-06-2015, 10:49 PM | #383 |
nice job on the header. that wiring looks fun!! I actually don't mind wiring but dang. are you going to use the harness to wire the whole truck? or get an aftermarket harness and use this for the engine? seems its what most guys do.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-07-2015, 09:39 AM | #384 |
Thanks for the links JJ. That makes me feel better about mounting my rad. What rad is that from R'n'D Fab and about how much was it? What fan is that too? Didn't see any part #'s in your build thread. Nice to see you have done the hard work of figuring out the hoses too for me. LOL!
Not sure on the wiring harness yet 99. I just grabbed everything I could. Not afraid of wiring either. Plan on having the fuse panel and PCM in the cab somewhere. I want to hide as much of the wiring in the engine bay as much as possible. I'm at a point where I have to spend some good $$ to move forward. Rad, gas tank with pump, lines etc. That much $$ is hard to pull off with the wife all at once. A few hundred here and there I can slip by. Cheers!
11-07-2015, 10:05 AM | #385 |
Found your rad JJ. I'm assuming you got the fan from them too. I will have to look into a more cost effective solution. That would be around $1000 by the time I get that here in Canada and with today's exchange rate.
11-07-2015, 10:37 AM | #386 |
From the looks of your engine Intake manifold, you have a drive by wire. Did you happen to get the Electronic accelerator petal and TAC box? If you also have the fuse block there are only about five wires you need to hook up to make the "stock" wiring harness run the engine/tranny. Good luck, and your project looks great.
Ricky
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
11-07-2015, 12:29 PM | #387 |
Yes it is DBW and I did get the pedal and TAC box from the same truck the ECM and harness came out of. 04 GMC.
11-07-2015, 12:54 PM | #388 | |
The nice thing about the R and D radiator is the mounts are the same shape as stock - so I could have installed a stock radiator, or any stock replacement, the same way.
11-09-2015, 07:04 PM | #389 |
Manifolds look good I think it should work fine. Only thing I see is you might have to open up the bolt holes a bit because of the new angle.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-12-2015, 02:58 PM | #390 |
I think you are right lower. Found a set of used Hooker LS cast headers for a decent price so I will see how those fit when I get them.
Started putting the engine back in the frame and cab back on to make sure I make enough room in the firewall. I'm pretty tight with truck accessories and stock rad location. Been searching radiators and wow! information over load. Anybody have a part number for a rad they used with an LS? All I pretty much see is "I used a champion and fit great". Champion offers so much. Kinda thinking a rad with inlet and outlet both on the passenger side. Any suggestions on that? I have found one but too much $$$ especially to get it up here to Canada and with how our dollar sucks to the US dollar.
11-12-2015, 07:17 PM | #391 |
I had my 4 core rad custom made from a local rad shop for $700.
As for the brake booster. I have a spare hydro boost from a astro van, if you want it it's yours.
11-12-2015, 08:32 PM | #392 | |
11-13-2015, 09:03 AM | #393 | |
I just went through his build again the other day and if memory serves correct, he also used a Champion. I bet he has a part number. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-13-2015, 09:39 AM | #394 | |
Ask them how they get the ram air out of the shroud (providing you have one) when you use a electric fan? We are having trouble with our PRC!
11-13-2015, 09:56 AM | #395 |
I have a spreadsheet showing which wires need retained for standalone operation. Pm me your email and I can send it to you as its too large to attach.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
11-13-2015, 10:02 AM | #396 | |
I'm out to lunch on master cylinders, hydro boost etc. Is there an advantage to running hydro boost over vacuum? I will be running 1996 Vette front and rear disk brakes. May take you up on your offer. Mighty fine of you.
11-13-2015, 10:20 AM | #397 |
Some amazing fab work. Beautiful build.
2010 dodge 3500 dually (Cummins tow pig) 2010 CTS-V 2003 TT 03 Cobra The BUILD!!! 1955 GMC series 1 This build is a wedding present to my soon to be wife. She has no clue. But I'm building her dream truck and hands down one of my favorite vehicles of all times. |
11-13-2015, 10:22 AM | #398 |
Nice rads but don't see prices. What did you pay or am I afraid to ask.
11-13-2015, 10:23 AM | #399 |
Thanks and will do!
11-13-2015, 10:23 AM | #400 |
