10-09-2015, 02:18 PM | #1 |
Pulloff Parts
Looking to get rid of some pull off parts that I no longer need. Let me know if you may be interested.
Here is everything I am looking to get rid of now. Details below.. 1966 OE Instrument Panel. As far as I know, the only working gauge is the speedo/odometer, which I reset, so it now shows 1318mi. though, it works well. SOLD!
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 Last edited by morethanstock66; 10-13-2015 at 01:30 PM. |
10-09-2015, 02:22 PM | #2 |
One foot in front of the other
Re: Pulloff Parts
Prices for the other parts?
10-09-2015, 02:25 PM | #3 |
Re: Pulloff Parts
Edelbrock 600CFM Maunal Choke Carb (1405). Was used for approx. 1500mi. It is dirty, but runs quite well. $125 Comes with Choke cable and new carb Manual kit....Now $95 + Ride The Edelbrock knob Manual Choke Cable is 68in. from hook to end of h the hard mounting tube at the knob end. Perfect length for these year model trucks to the dash mount hole.
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 Last edited by morethanstock66; 10-12-2015 at 10:28 AM. |
10-09-2015, 02:26 PM | #4 |
Re: Pulloff Parts
Sorry I took too many pics. Updating as I go. Only five pics per post..
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
10-09-2015, 02:30 PM | #5 |
But Found Her 25yrs Later!
Re: Pulloff Parts
How much for the gauge cluster?
10-09-2015, 02:35 PM | #6 |
Re: Pulloff Parts
I pulled the points distributor after I purchased my truck and immediately went to HEI. I do know it ran briefly, but I would replace the guts and just use the housing, if I was you. Distributor: $35... Now $25 +ride I used this HEI cap for approximately 1500mi. It does show some carbon build up, but that is it. NOTE: this is without a control module, though the coil does still work. It will run, if you add a control module. Cap & Rotor: $30... Now $20 +ride
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 Last edited by morethanstock66; 10-12-2015 at 01:52 PM. |
10-09-2015, 02:39 PM | #7 |
Re: Pulloff Parts
Gauge cluster= $75 plus a ride. Note the description, only fully functional gauges I know of are speedo and odometer. You may get lucky and some of them can be fixed, I just swapped mine.
10-09-2015, 04:40 PM | #8 |
Re: Pulloff Parts
Updated prices...I would rather not throw it away..
10-09-2015, 04:45 PM | #9 |
Re: Pulloff Parts
How about $50 + the ride, instead. I updated the prices
10-09-2015, 05:23 PM | #10 |
I'm just glad to be here!
Re: Pulloff Parts
I will be in Frisco on Sunday for a Gymnastics meet with my Daughter. I am interested in the Carb and the Dist. I will PM you my number if you don't mind texting yours to me.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-09-2015, 07:37 PM | #11 |
Re: Pulloff Parts
If lost my 65 passes put me in line for the cluster.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-10-2015, 07:18 PM | #12 |
Re: Pulloff Parts
Will do.
10-12-2015, 10:29 AM | #13 |
Re: Pulloff Parts
aggie91 passed via text. Carb. and dist. are back up
10-12-2015, 12:08 PM | #14 |
Re: Pulloff Parts
Sorry, I'll pass on the gauges.
10-12-2015, 03:05 PM | #15 |
Re: Pulloff Parts
If PG passes on gauges, put me in line
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356 |
10-12-2015, 05:24 PM | #16 |
Re: Pulloff Parts
10-12-2015, 05:25 PM | #17 |
Re: Pulloff Parts
Were you wanting the cluster?
10-12-2015, 05:49 PM | #18 |
Re: Pulloff Parts
Let Daddyoh have the cluster.
Jimmy
10-12-2015, 06:22 PM | #19 |
Re: Pulloff Parts
PM me total price to 92234 and PayPal info
10-13-2015, 01:29 PM | #20 |
Re: Pulloff Parts
Gauge cluster is sold.
