Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 02-10-2017, 03:27 PM   #1
ItsJakey
Exclamation Is this truck worth the price??
Hi, I've got first dibs on a truck that im going to look at tonight. Looking for replies asap. Please don't contact him, I've already got first dibs, he lives about 30 minutes from my house.
only rust is on outer rockers & a peice of the cab to frame mount.
Original frame
Is it worth it??
https://joplin.craigslist.org/cto/5995328393.html
ItsJakey is offline   Reply With Quote
Old 02-10-2017, 03:34 PM   #2
bs46488
Re: Is this truck worth the price??
I like it.
Seems reasonably priced.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 02-10-2017, 03:44 PM   #3
OARNGESI
OARNGESI's Avatar
If say is reasonable of it's a factory swb
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-10-2017, 03:51 PM   #4
tutone
tutone's Avatar
I'm not a fan of LS swaps but you may be. As the previous poster said if its a factory sb, then its a buy. I think my next one may be a 4x4 too. Good luck to you.
tutone is offline   Reply With Quote
Old 02-10-2017, 03:58 PM   #5
CUSTOM/10
CUSTOM/10's Avatar
If the vin numbers on the frame, vin tag & spid sheet all match and it's a solid truck, I would say yes.
If it's a rot box, the vin numbers don't match or the frame was a long box and shortened then I'd say no !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 02-10-2017, 03:59 PM   #6
onebigjohn
onebigjohn's Avatar
Questions:
What trans?
What transfer case?
Rear disc brakes....What calipers?...E-brake?
Things you should know...Safety first!
Frankintruck or OG?
"I pawned my Hanso"
"Hold my beer, Watch this"
onebigjohn is offline   Reply With Quote
Old 02-10-2017, 04:11 PM   #7
ItsJakey
He said something about a gears matching t-case. Not sure on calipers, Not sure on e-brake.
What should I look for to see if it was a longbed that has been shortened?
Old 02-10-2017, 04:37 PM   #8
Mryan
Active Member
I spent more for less.....
Mryan is offline   Reply With Quote
Old 02-10-2017, 04:48 PM   #9
cypressbog
Go Pack Go!
No way in hell would I pay that much for that truck.
Am I the only one that sees the front axles seam to be forward? Something wrong here, either wrong frame or something else.
Dana 60's, non-correct brakes, 4:11? Sounds like this was someones mudding truck years ago. rode hard and put up wet.
For $7,500 you can find better.
cypressbog is offline   Reply With Quote
Old 02-10-2017, 05:39 PM   #10
GTORobo
I agree with Gary. The front looks like its been tweeked, the bumper looks higher on the drivers side. I would offer a little less.
GTORobo is offline   Reply With Quote
Old 02-10-2017, 05:59 PM   #11
Sicklajoie
The Niner
Sicklajoie's Avatar
That thing looks like it's got trouble written all over it. The wheel base looks off compared to the body for sure.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-10-2017, 06:09 PM   #12
B. W.
B. W.'s Avatar
Personally, I'd light myself on fire & run screaming from it!
B. W. is offline   Reply With Quote
Old 02-10-2017, 06:31 PM   #13
MYOUNG
The front tires are turned slightly to the right, so this might be why it looks the way it does. I would bring a tape measure and poke around a bit. Check the toe and check the thrust angle. Ask the seller to drive it in a straight line and stand behind it to see if it crab legs down the road.
MYOUNG is offline   Reply With Quote
Old 02-10-2017, 06:42 PM   #14
GR8-68
GR8-68's Avatar
The add says 70 but it has 71 72 grill not 70. I would definitely check it out good before signing the check.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-10-2017, 06:55 PM   #15
El Dorado Jim
the grill is from a 71-72, the K10's didn't come with 8 lug axles,those have been changed, truck looks a little rough, if you don't care if it is stock or not then it may be a decent deal, if in fact it does have a Dana 60 in the front, that alone is worth atleast $1500.00.nice having heavy duty running gear!...let us know if you get it or not.......
El Dorado Jim is offline   Reply With Quote
Old 02-10-2017, 06:59 PM   #16
jocko
jocko's Avatar
Frankentruck. Run away.
Old 02-10-2017, 07:21 PM   #17
Orange67
Orange67's Avatar
I've seen lwb c20 trucks cut down, LS converts going for this much, and no better quality. Is it the 4x4 part that you guys don't like? I'm just asking, not trolling.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 02-10-2017, 07:28 PM   #18
bhayes1
bhayes1's Avatar
I'm assuming the 4 speed is what came in it originally. With 4.11 gears and no OD then how much is that LS 5.3 going to benefit you. Looks like a lot of work still left to do.
1969 GMC K2500
bhayes1 is offline   Reply With Quote
Old 02-10-2017, 07:47 PM   #19
Coley
Coley's Avatar
Smile Re: Is this truck worth the price??
8 bolt wheels...on a swb, 1/2ton, 4x4...something big changed out there underneath the truck.
Probably put a '72 swb upper chassis on a 70's (80's?) frame and running gear.
So what you would be buying is a variety of trucks here...remember that plays into the value because it's unlikely someone will ever pay more for that combo'.
Let's back up a bit....what do you actually want?...what's your style and your 3 1-3 driving target?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-10-2017, 08:28 PM   #20
TwoFiftyShifter
I don't get it - you need overdrive to see the benefits of LS technology?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-10-2017, 08:29 PM   #21
TwoFiftyShifter
Looks like a $7500 project to me. Some oddities - I agree it looks like an old mud truck. Has potential at $5500.
1982 K10 SWB
Old 02-10-2017, 08:48 PM   #22
OARNGESI
OARNGESI's Avatar
Go check it out if it drives good especially at hwy speeds and the rust ain't too bad Find if it's a cut down k20 newer frame stock frame what if it's a stock k10 with updated axles and a LS you are probably not too far off.
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 02-10-2017, 09:11 PM   #23
tommys72
tommys72's Avatar
Looks to me like both front fenders have been cut for bigger tires. Probably has been mudded, frame could very well been tweaked.
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 02-10-2017, 10:45 PM   #24
El Dorado Jim
also, the transmission and transfer case shifters are not stock for 72 and older, they are 73 or newer....
Old 02-10-2017, 11:42 PM   #25
redbaron
redbaron's Avatar
No it's not. That is a pieced together truck. You can find a way better truck for $7500. Not only would I walk away...I'd run.
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
1970, cool, ls swap, ls swapped, shortbed
