Old 04-09-2020, 06:45 PM   #1
Jcfcamaro
Jcfcamaro's Avatar
NP 205 transfer case leak
Thought I'd post this to help anyone with a np205 transfer case leak at the speedo drive. Reading different post the factory used a oring on the pinion shaft but is pretty prone to wearing out and leaking so GM started selling new adapter nuts with a larger I.D from .506 to .579 to have a press in seal to help hold back the oil, but now are discontinued by GM # 326561. Other places are making the same adapter nut with the new style seal but the I.D of the seal was larger than my .250 shaft size. Ended up going to napa auto parts and looking through there seal book and found a seal that would fit my .250 shaft and also the .506 O.D part number 2450 SKF brand. The seal fits perfectly on the shaft I.D but just barely catches the inside of the nut where it presses into( nut Is .506 and the O.D of seal is .505) but with some bearing epoxy or a punch with some light Mark's made inside the nut it will hold fine. Just thought I'd make this post to help anyone with the same issue. P.S the new style nut is around 50.00 vs this seal I bought was 5.99.
Jcfcamaro is offline   Reply With Quote
Old 04-09-2020, 07:10 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: NP 205 transfer case leak
Here's me with a punch and making some light dimples to hold the seal once I press it in. I will also use a lite film of RTV silicone around the outside of seal to make sure it seals .
Old 04-18-2020, 10:43 PM   #3
v30crewcab
v30crewcab's Avatar
thats good info. thanks.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-21-2020, 08:34 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Thanks for the info! I’m sure I’ll be crossing this bridge in the next few months as my K20 nears being road ready. Thanks for taking the time to not only figure this out but for sharing it as well.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 04-21-2020, 12:19 PM   #5
Jcfcamaro
Jcfcamaro's Avatar
I will say when I put everything together I installed the gear shat into the nut/seal first then put it in the speedo housing. Putting the gear in first then trying to screw the nut in and aligning the shaft with the seal was a little hard and I was afraid of damaging the seal so that's why I put the gear into the seal first and used a small pick to help walk the seal around the shaft. Once it was together I used a small screw driver inside the square hole where the speedo cable goes in to help steady it while I screwed it in and tried to catch the other bushing inside the housing that the other end of the gear goes into. Hope this makes sense and you might be fine installing the gear first then screwing the nut on. This is just what seemed to work better for me.
Old 04-23-2020, 04:26 PM   #6
El Dorado Jim
thanks for the info
El Dorado Jim is offline   Reply With Quote
Old 02-21-2021, 07:59 AM   #7
jjzepplin
jjzepplin's Avatar
Thank You for this info. Do you have an update as to whether this solved the leak long term?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-21-2021, 10:28 AM   #8
Jcfcamaro
Jcfcamaro's Avatar
No update as I'm still building my truck, but I can't imagine it not working.
Old 02-22-2021, 07:43 AM   #9
jjzepplin
jjzepplin's Avatar
I was thinking I could possible "flare" out the lip of the seal so it would fit better. It's cheap enough so I will try it.
Old 02-22-2021, 09:57 AM   #10
Jcfcamaro
Jcfcamaro's Avatar
Great idea. I'd use a little RTV also.
