06-01-2020, 11:37 AM | #1 |
K30 Differential swap
I picked up a complete 1986 Chevy Pickup K30 for a donor for my 1968 Suburban / Cummins project.
I believe the front Dana 60 is a direct bolt in but I'm not sure about the rear 14 Bolt differential - anyone swapped into a 1968 Suburban 4x4 frame? Also I believe they are close to same width as original equipment? What mods were required? Thanks in advance.... |
06-01-2020, 01:05 PM | #2 | |
Re: K30 Differential swap
06-01-2020, 03:01 PM | #3 |
I've heard there are differences between the 3/4 and 1 ton 14b. I used a 3/4 ton 14 in mine and had to move the shock and spring mounts. Since yours is from a K30, you might not have to move the spring mounts.
Width is fine. There are disc brake conversions for the 14b if you wanted to do that while you are at it. |
06-01-2020, 10:20 PM | #4 |
SWB 4x4 Collector
A rear 14 bolt from a K30 is a direct bolt in. Spring Perches are already lined up. You might have to move one of the shock mounts.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
