12-13-2017, 05:52 PM | #1 |
Rack and pinion
Hey guys, anybody know of any decent Non-power rack and pinion setups for our rigs, preferably bolt on? I've seen all the power, new setups for like 1500. But I'm looking for something a little more budget friendly for the time being. My current power-setup is rather s****y lol.. Thanks fellas!
12-13-2017, 08:52 PM | #2 |
Re: Rack and pinion
I second that, I would like to change mine to a manual rack.
http://67-72chevytrucks.com/vboard/s...d.php?t=765151 |
12-13-2017, 09:01 PM | #3 |
Moderator
Re: Rack and pinion
I wonder if you called these guys and asked them if they would sell you a manual unit, would they do it?
http://www.unisteer.com/c10/60-66-ch...inion-kit.html
12-13-2017, 09:05 PM | #4 |
Re: Rack and pinion
Can't hurt to ask...no is the worst it can get
12-13-2017, 09:50 PM | #5 |
Re: Rack and pinion
Would a manual rack and pinion require less steering effort than the factory manual setup? I just wonder, because if the steering ends up being a bear to turn then you may soon find yourself wishing it was power assisted. I don't mean to be "David Downer" here, but I sure would want know what to expect before making a purchase of that caliber.
12-13-2017, 10:07 PM | #6 |
Re: Rack and pinion
Dave you make an excellent point. Thats why I was factoring in cost with it. I mean, if a nom power will run over 500, there is no point to going that route instead of just spending the extra few hundred for the power assist package.. But if there is a manual rack less than a 3rd of the price that will suffice until funds are available, I would def go that route. But I do agree with you on doing it once, and doing it right lol..
12-14-2017, 09:33 AM | #7 |
Re: Rack and pinion
I doubt you'll find a manual rack with a ratio that makes it easy enough to steer for something as heavy as a truck. I'd think that most racks are quicker ratio than a 70's/80's power steering box, so imagine one of those with no power but a faster ratio that gives you less leverage.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-14-2017, 11:19 AM | #8 |
Re: Rack and pinion
You could buy a 70's style truck power box, pump, and hoses from O'reily's or whatever, find a DD shaft/rag joint assy from a squarebody, order a Captain Fab adapter bracket, and still get a new paintable steel column from ididit or the like and not totally break the bank. Then you'd be like new from top to bottom.
12-14-2017, 12:37 PM | #9 |
Re: Rack and pinion
I run a manual Flamming River 3:1 on Porterbuilt '62 front. Its quick. I got to ease up on wheel when I shift or will change lanes. Like driving a go kart. Great at hiway speeds. Parking about same but a 245/45/18 vs a 235/60/15 is a bit more effort. A rack is not as tight as stock turn. I like the quick ratio but have got use to it, PB suggested the standerd one. 15" mooneyes wheel, a fatter wheel might be more comfortable.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
12-14-2017, 01:30 PM | #10 |
Re: Rack and pinion
See, this is why I love you all lol! Great input, thank you guys. I am just going to continue with the box i have for now, just replace the power steering hoses, and upgrade the column first (getting loud grinding noises during turns, and sometimes it gets "stuck" and have to break it free.) Its a mid 70s c20 box, but it leaks fluid from both hoses. Eventually I am going to upgrade to the power rack and pinion kit, but it looks like for now I'll make some smaller cheaper fixes. If anybody knows a good later model column thats a pretty easy bolt in for ours that would help! Tilt preferred
12-14-2017, 05:02 PM | #11 |
Re: Rack and pinion
I've been down that later model column road a few times. Most recently with a '70 Coupe de Ville tilt/tele. But I've also done others. It's always a PITA especially with regard to the e-brake handle and mechanisim. Also steering wheel placement often winds up being too close to the driver resulting in further mods which makes shifter placement dicy. Last time I swore I was done using 30+ year old junk and contorting myself under the dash. If I ever do another column I'm going to call ididit. People say they have good luck with van columns and motorhomes due to the smaller tube diameters but those are about as rare as hen's teeth in my neck of the woods.
12-14-2017, 06:09 PM | #12 | |
Re: Rack and pinion
Basically it's a freakin domino effect puzzle lol. Making sure this piece fits with that piece, and the puzzle comes together. |
12-14-2017, 06:59 PM | #13 |
Re: Rack and pinion
12-14-2017, 07:11 PM | #14 | |
Moderator
Re: Rack and pinion
12-14-2017, 07:21 PM | #15 |
Re: Rack and pinion
Apparently, it's possible to upgrade to the '66 style which doesn't use the bar and slot at the cross member. The link is a current thread and he's still sorting out the details, but you could contact him and see how it goes. http://67-72chevytrucks.com/vboard/s...d.php?t=752354
12-14-2017, 08:37 PM | #16 | |
Re: Rack and pinion
Rock, what is your setup you're working with? Is it a manual setup or electric like the one LV posted? Anybody seen any Lokar or any up front linkage that attaches right to our stock cables? I remember seeing CaptainFab post something about a Lokar setup on a customers Nova a while back. Never could find out what he was talking about connecting the 2 though. Paging CaptainFab haha |
12-14-2017, 08:46 PM | #17 |
Re: Rack and pinion
Ok, so browsing Summit, this looks like a "universal type" unit, as long as I mate it with a Lokar shifter. Would this mate up to the original linkage with some modifying?
https://www.summitracing.com/parts/lok-xehb-7016 |
12-14-2017, 10:41 PM | #18 |
Re: Rack and pinion
And there is a tilt column complete unit out of what looks like a late 70s chevy car (monte carlo maybe) on craigslist for 75. Anybody know what that would be like to try and make work?
12-14-2017, 10:44 PM | #19 |
Moderator
Re: Rack and pinion
You could use your own brake handle and do this under the cab.
12-14-2017, 11:23 PM | #20 |
Re: Rack and pinion
12-15-2017, 12:01 AM | #21 |
Moderator
Re: Rack and pinion
They are on lokars web site under accessories I think. Also cables they have there and here: http://www.controlcables.com/
Also here is a type of bracket: http://www.controlcables.com/parking-brake-controls/
12-15-2017, 11:16 AM | #22 | |
Re: Rack and pinion
12-15-2017, 01:16 PM | #23 | |
Re: Rack and pinion
12-15-2017, 01:16 PM | #24 |
Re: Rack and pinion
12-18-2017, 10:30 PM | #25 |
Re: Rack and pinion
I have a 66 i can send you pictures if needed.
