Old 09-02-2020, 09:29 AM   #526
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 1971 Stepside LS Build
Finally some color! Are they cutting and buffing too?
Yes, it will be started today. Probably take the frame back out next week to begin assembly
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-02-2020, 01:13 PM   #527
TA_C10
TA_C10's Avatar
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 09-02-2020, 03:13 PM   #528
Custom 68
Custom 68's Avatar
Perfect color Shannon! I bet you are grinning from ear to ear.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-09-2020, 11:19 AM   #529
1971Stepside
Almost Satisfied
Continuing to work on the exhaust. I have very little clearance between the H-pipe and the trans cross member. I am not sure if this will present a problem. According to Holley the system should be rigid all the way to the headers and not use the flex pipe. The hangers allow for flex.
Old 09-09-2020, 11:45 AM   #530
TA_C10
TA_C10's Avatar
Hey man, I have that same clearance in a couple spots and no issues hitting. My exhaust is using rubber isolators similar to yours. So that isn't rigid mounting. If you used the flex's at headers, then rigid mounting would be hanging the exhaust directly to the frame with no isolators. Right?
Anyway, you should be ok. If you grab the exhaust and rock it back and forth, does it touch? (put a rag in between that fresh paint first ) I think my clearance is 3/16" in one spot. And I have drove it around the neighborhood a lot, and took it down a backroad a couple times giving her h3!! and no rubbing when I got back and looked.
"It's only money".
Old 09-09-2020, 11:56 AM   #531
1971Stepside
Almost Satisfied
It doesn't move at all. Thanks for confirming.
Old 09-09-2020, 11:57 PM   #532
cornerstone
cornerstone's Avatar
Same here. My exhaust system is that close to the frame and cross members in a few places. The only way the system can move is at the rubber in the hangers, to allow for heat expansion. You may want to keep an eye on it though since you have a nice paint job on your chassis, but I imagine the heat will have dissipated enough by the time it gets to the trans cross member. You're going to have a one of a kind special truck in the near future...
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 09-11-2020, 06:49 AM   #533
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Yes the system should be rigid and not include flex pipe. I questioned Holley on this in the following thread. They explained it quite well. Keep up the good work and forge on man.
https://67-72chevytrucks.com/vboard/...d.php?t=790866
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-14-2020, 09:55 AM   #534
1971Stepside
Almost Satisfied
Wrapped up the exhaust this weekend. I'm very pleased with how it turned out. I had to wire everything back up and put my temp hydroboost holder back on so I could fire it up and listen to it.
Old 09-14-2020, 10:22 AM   #535
TA_C10
TA_C10's Avatar
That exhaust looks great man. The frame is just killer. You will have to keep us updated on those slip style clamps. I cannot speak with experience but I have read everywhere they don't hold over time. But I take that with a grain of salt cuz it's all coming from the internet
I see how the exhaust appears to have shifted to the left on you both sides, it's close to frame up by LH bank header, and also close at the pass-thru on RH side cross member. But looks like there is plenty of room though. Exhaust moves SO MUCH when final welding everything, I learned this the hard way and had to cut and reweld a couple places.... It's still too close for comfort over my trans cross member...
Love it man, can't wait to see it with the body on.
"It's only money".
Old 09-14-2020, 10:30 AM   #536
MDPotter
MDPotter's Avatar
That is one clean chassis. How was the sound? What I don't like about my black widows is the have the "clapping" sound (for lack of better term) at certain RPM's and throttle.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 09-14-2020, 11:03 AM   #537
1971Stepside
Almost Satisfied
I have read that too. If they do then we will have to get it all TIG welded up. I plan to add cutouts at some point, so that may be the time to do it. The pictures do make some spots look closer than what they are. I spent a lot of time adjusting and getting it as much clearance as I could at all points.
Old 09-14-2020, 11:05 AM   #538
1971Stepside
Almost Satisfied
They have a throaty sound similar to a new Camaro, but probably not as loud. It a little hard to tell until I get the body back on because with it just being a frame you hear the engine sound much more than you will.
Old 09-18-2020, 10:09 AM   #539
1971Stepside
Almost Satisfied
Cut and polish continues. Hope to start assembly next week on the cab, doors, and fenders.
Old 09-19-2020, 10:58 AM   #540
TA_C10
TA_C10's Avatar
Wow man, that paint is gonna be awesome.
"It's only money".
Old 09-22-2020, 09:19 AM   #541
1971Stepside
Almost Satisfied
The day finally came where the frame goes back to the shop to meet up with the body. I rolled it out in the driveway and waited for the trailer to show up.
Who knows if they will get it back on the frame when they said, but it feels like progress. Hopefully, it will be home this weekend.
Old 09-22-2020, 09:23 AM   #542
IronCanine
I'm trying....
IronCanine's Avatar
It is real progress. Great build. Can't wait to see them married.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 09-22-2020, 09:34 AM   #543
KMC3420
KMC3420's Avatar
Your detailed planning and execution is coming together nicely. Excellent progress IMO.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 09-22-2020, 09:36 AM   #544
MDPotter
MDPotter's Avatar
One of these days very soon we're going to get an update and it's going to be a picture of body on frame and it's going to be huge! It's really a one-off truck.
Old 09-22-2020, 09:37 AM   #545
71cadc10
71cadc10's Avatar
love the build....looks great. I was looking at your pics and realized we have very similar tastes on color and wheels LOL.
mine is 04-06 GTO Quicksilver metallic, with antique white lower. looks like the same silver you went with. Your chassis and build are on another level!!
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 09-22-2020, 11:19 AM   #546
1971Stepside
Almost Satisfied
Thank you! I can't either...
I never dreamed it would take from April 3rd until now to get this far, so my planning is very different from my buddies shop. I don't complain to him at all since I am getting a 20k plus paint job for a very discounted rate.
LOL, right? I hope you get to see it Monday, but I'm being optimistic
You have a great looking project going as well. I like the two tone and I'm glad to see the wheels work with the silver. Mine is a Chrysler color from the Dodge Hellcat called Triple Nickel. It looks close to yours for sure.
Old 09-22-2020, 11:23 AM   #547
Custom 68
Custom 68's Avatar
Wahoo.. You are moving forward for sure. These fine details do take some time.
You will certainly enjoy it!
Dave
Dave
Old 09-22-2020, 02:25 PM   #548
71cadc10
71cadc10's Avatar
Ah cool....I was skimming thru and saw you were looking at GM truck silver of some type. The triple nickel Dodge color will look killer
I saw you discussing the Precision push on door seals...I just put the driver side on. Seems to be 1-2" short on overall length, and you gotta slam it firm due to the pressure. Maybe my door openings got too big LOL?
I took a pic of the package tag, I think these are the '2nd' design but don't recall when I bought them.
curious your experience with them when installed.
I have a set of glue on soft-seal, might try that on the passenger side
Old 09-22-2020, 10:58 PM   #549
TA_C10
TA_C10's Avatar
"It's only money".
Old 09-23-2020, 12:46 AM   #550
cornerstone
It's a long time a comin' man!! I bet you're dreaming about driving that bad boy every night.
Brian
