09-24-2020, 11:20 PM | #1 |
New headlights not working
Ordered a set of new led headlights from eBay but I can't get them to work properly, I ran a hot wire from the extra red wire to the + on the battery still nothing. I was told to do this by a local shade tree mechanic I don't know much about wiring.
As always all advice is greatly appreciated! Thanks in advance. '85 c10
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
09-24-2020, 11:31 PM | #2 |
Re: New headlights not working
LEDs are polarity specific...ground has to be ground, and hot has to be hot...cant tell much from your pic.
09-25-2020, 06:26 AM | #3 |
Even if the old incandescent bulbs worked fine, if you are reusing the original headlight plugs, possible that corrosion is preventing a good connection. It doesn't take much size difference to cause problems between old sockets and new inserts.
09-25-2020, 06:56 AM | #4 |
You may need relays to get the bulbs to have sufficent voltage.
09-25-2020, 07:14 PM | #5 |
You'll probably need to repin your connector. LEDs often are wired to H4 pattern, just gotta swap two wires around in the connector.
Alex. |
09-26-2020, 12:21 PM | #6 |
like posted above in the pic .
lots of these cheep ebay / amazon - china crap pattern led swap bulbs have the wiring problem . my good ones do NOT they were plug and play no problems . white light / great pattern / no one flashing me from being blinded . yes there big bucks but super quality . j.w. speaker units.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-26-2020, 08:52 PM | #7 |
Thanks I will try this in the morning.
09-26-2020, 08:55 PM | #8 | |
09-27-2020, 08:39 AM | #9 |
I wouldn't say its always cheap lights either, lazy/minimizing minor stock changes for what is essentially an unnecessary part number since h4 & 45xx use the same connector, on the lazy side, they should be throwing in a sheet with the above that says if you are using them in a 45xx system repinning will be necessary (h4 being by far the most common, especially from an asian/euro perspective).
