04-08-2019, 10:36 AM | #1 |
WTB: Inside Door Handle For '98 Tahoe
I need the drivers-side and whatever attaches too it. Thank you.
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
04-15-2019, 12:04 PM | #2 | |
Questionable
Re: WTB: Inside Door Handle For '98 Tahoe
Everyone knows Dorman brand, but the OER brand handle is supposedly the closest you can get to stock. For part numbers... you can take these numbers and plug them into Summit's search box directly and see results for you if you've got tan (neutral) or grey interior: 15708051 -> Handle, Inside, LEFT (NEUTRAL/TAN) 15708052 -> Handle, Inside, RIGHT (NEUTRAL/TAN) 15708043 -> Handle, Inside, LEFT (GRAY) 15708044 -> Handle, Inside, RIGHT (GRAY) Note that GM Parts Direct also still sells the OEM part, but for 6x more than the re-pops. Parts numbers and stuff are available with exploded diagram here. https://www.gmpartsdirect.com/auto-p...-hardware-scat I just prefer GMPD because I helped build their first websites back in the late 90s and the folks running it back then were awesome
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-16-2019, 06:30 AM | #3 |
Thank you!
04-17-2019, 07:18 AM | #4 |
Stock is nothing to brag about since they so commonly fail they are laying on shelves at Advance auto parts in a variety of colors. I've replaced mine.
04-17-2019, 02:04 PM | #5 |
I won't spend the $1000 on nos then!
04-17-2019, 04:22 PM | #6 |
I have replaced the driver's side indoor handle on a suburban and a truck with after market. The handle works and fits fine. The door lock switch operation on both was and still is not smooth. The remote lock/unlock is used anyways so it does not matter.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-12-2019, 07:41 AM | #7 |
Still plays with trucks
Some of the lack of smoothness is the build up of crud on the latch & lock mechanism. One of my rear doors on my 98 Tahoe wouldn't unlock with the rest on command all the time so I tore into it and found it was pretty gummed up. De-greased and cleaned up the assembly then re-greased it properly and the lock worked great.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-12-2019, 01:45 PM | #8 | |
