Old 11-15-2014, 03:37 PM   #1
54blackhornet
54blackhornet's Avatar
GMC Headlight Trim Surround Question ?
This is for the 4 eye experts, I found a real nice pair of GMC headlight trim surrounds "Rings" at a local wrecking yard. They cleaned up real nice with a little metal polish. When I went to install them, no way will they fit ? I did not realize there was a difference between the early slant nose models and later ones? I also found out they are not Stainless, I was under the impression GMC'S had Stainless Grills and Chevys had Anodized Metal?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-15-2014, 03:41 PM   #2
john
member #16
john's Avatar
Re: GMC Headlight Trim Surround Question ?
GMC's were chrome plated steel grills.
john is offline   Reply With Quote
Old 11-15-2014, 06:43 PM   #3
davepl
davepl's Avatar
I had my rechromed, so I've got to assume John is correct. My '70 doesn't have rings per se, it has a "plate" with two holes (for the headlights). Sorry the outboard one is a little crooked, I have to add a notch to the bucket to get the aftermarket lamp assembly properly vertical.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-16-2014, 10:32 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
I had a 71 GMC. The grille, headlight rings and "hood bar" were all just chrome plated steel. Im not sure if the slant hood models were different from later models. Have you double checked to be sure you don't have them swapped side to side or upside down?
WIDESIDE72 is offline   Reply With Quote
Old 11-16-2014, 11:08 AM   #5
54blackhornet
Trying to confirm if they are the same between 67 & 72 ? I tried to mount the pair I picked up at a salvage yard but had no success. Trying to mount them on a 71 ? I had a 68 with painted "Plates" "Surrounds" "Rings" what ever you call them and if I remember correctly, they looked thinner front to back ? Anyone know for sure? Part numbers ?
71 C-20
07 Magnum RT AWD
Old 11-17-2014, 04:43 PM   #6
54blackhornet
Still trying to determine if the trim is same or different between 67-68 & later years ?
71 C-20
07 Magnum RT AWD
Old 11-17-2014, 11:34 PM   #7
davepl
davepl's Avatar
Have you checked the parts book? Find it in the book for your year, and the year you wish to install it on, and see if its the same number.
I would imagine there are chrome and bare steel (for painted front ends), but other than that I cannot see why there'd be more than those two variants (for GMC, anyway) each year.
Old 11-18-2014, 04:29 PM   #8
73737373
Use an SOS pad to clean them.
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 11-18-2014, 04:49 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Are you referring to the headlight bezels? LMC has them under the same PN for 67-72. Those are for the chrome ones. That's not to say GMC didn't use a slightly different grille/covers for the non painted (doesn't make sense, but possible...)
...and pics always help! A LOT!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-18-2014, 05:15 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
I think they all should interchange. Did you personally pull these off of a gmc yourself? I am thinking they may be from a car that look similar. I think pontiac had bezels that look similar.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
