Old 11-21-2017, 10:32 PM   #1
kamkam1
Suspension and disc conversion kits
Having trouble trying to decide on a suspension and brake conversion kit. Just want to do it right the first time. Going to be daily driver, lowered 3.5/5 but handle well. Looking for recommendations on which kits ECE, MAGAUHYS, BROTHERS, CPP, not wanting break the bank...Thanks in advance
Kirk Myers
68 chevy swb owned since 87, under the knife
71 skylark 9.20's @ 76mph 1/8 mile
kamkam1 is offline   Reply With Quote
Old 11-22-2017, 12:13 AM   #2
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Re: Suspension and disc conversion kits
I went with ECE 2 1/2 spindles and 1 1/2 springs for the front. I wanted 2in springs but the guy that was helping me recomend 1 1/2 instead for a daily driver. He was right! I drive real hard But it hardly bottoms out Front snubbers cut in half. Rear coils swapped for 2500 lbs convoulted bags NO LIMIT shock relocators and panhard bar.Cheap monroe shocks but it rides and drives great. No info on brakes yet but planning on wilwood D52 calipers front and rear with CAPITIN FAB brackets for rear with awd astro van front calipers on rear.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
Last edited by 71cheyennesuperlongb; 11-22-2017 at 12:18 AM. Reason: Forgot about the brake part of question.
71cheyennesuperlongb is offline   Reply With Quote
Old 11-22-2017, 08:56 AM   #3
kamkam1
Old 11-22-2017, 08:57 AM   #4
kamkam1
Originally Posted by kamkam1 View Post
Thanks..
Old 11-22-2017, 12:26 PM   #5
bs46488
I think the key is the drop spindle. ECE gets a lot of good recommendations.
The previous owner did a full 3 or 4 inch drop spring on the front of my truck. It rides horrible and has a nasty bumpsteer issue. He cut the bump stops (with what I assume was an axe or maybe a hatchet) I'm sure that the truck hits the bump stops frequently while driving
I plan on buying drop spindles and a 1" springs from ECE and all Moog parts to rebuild the front end. Then get an alignment to correct these problems.
For brakes, I converted to hydroboost with disc up front and drums in the rear. All rebuilt with factory parts from Rockauto.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 11-22-2017, 08:31 PM   #6
kamkam1
Thanks for your experiences, nice builds.
Kirk Myers
Old 11-23-2017, 02:13 PM   #7
kamkam1
Narrowing it down to ECE or Maguahys...
Kirk Myers
Old 11-23-2017, 02:43 PM   #8
68Stepbed
68Stepbed's Avatar
ECE!!!!!! Just order the kit without the KYB shocks and get the correct lowered shocks. CPP sells some or get the Ridetech HQ shocks if budget allows.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-23-2017, 04:10 PM   #9
kamkam1
Thanks 68stepbed..
Kirk Myers
Old 11-23-2017, 10:04 PM   #10
franken
I wonder about replacement parts in the future.er
Old 11-24-2017, 01:36 PM   #11
68Stepbed
68Stepbed's Avatar
Another good reason to buy from ECE. All their stuff uses OE or off the shelf parts.
Matt
Old 11-24-2017, 04:42 PM   #12
MySons68C20
MySons68C20's Avatar
Fantastic experience with ECE I highly recommend!
MySons68C20 is offline   Reply With Quote
Old 11-24-2017, 11:06 PM   #13
kamkam1
Thanks everyone ECE it is, thanks
Kirk Myers
Old 11-26-2017, 11:14 AM   #14
kamkam1
Finally decided on ECE brake and suspension, but there website will not give me the shipping cost. So I’m unable to complete my order. Anyone else having trouble? Thanks
Kirk Myers
Old 11-26-2017, 02:02 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Call them tomorrow.
They might even give you a discount for their website error.
They have the best customer service.
Plus they can make sure you are getting everything you need.
Keith
Convert to disc brakes.
Old 11-26-2017, 04:15 PM   #16
kamkam1
Yea, planning on calling first thing tomorrow. Hopefully they can help. Thanks for the replies..
Kirk Myers
Old 11-27-2017, 10:32 AM   #17
68Stepbed
68Stepbed's Avatar
If I'm not mistaken, they may even offer a discount for being a board member here.
Matt
Old 11-27-2017, 03:49 PM   #18
kamkam1
Called ECE and they were super friendly, ordered all my parts and I highly recommend them for c10 needs....Thanks Kirk
Kirk Myers
Old 11-28-2017, 10:17 AM   #19
68Stepbed
68Stepbed's Avatar
Matt
Old 11-28-2017, 06:03 PM   #20
Indian113
Indian113's Avatar
I have been putting off replacing my Drum Brakes with Disc as I tried to digest all the Information on this Site! I Finally pulled the Rope and Bought a MaGauhy's 6 lug Kit for my 64. It is the one that uses the stock Drum Brake Spindles. I went that way as I rebuilt the Complete Front End less than 1000 Miles ago. I got the Kit from Carid for $284.05 with a Coupon and Free Shipping. Nothing Fancy Cast Rotors and Rubber Brake lines. If anybody is interested the Kit # is 63157 and the SKU # 199418602. Haven't made my mind up on Master Cylinder set up yet.
Indian113 is offline   Reply With Quote
Old 11-28-2017, 08:18 PM   #21
kamkam1
Thumbs up Re: Suspension and disc conversion kits
Nice..
Kirk Myers
Old 11-29-2017, 01:40 PM   #22
bs46488
Kirk,
So what did you end up buying?
Old 11-29-2017, 06:47 PM   #23
kamkam1
I bought the 6 lug disc conversion with 2 1/2” drop spindles and the 3.5/5 lowering kit with shock upgrade.. Jeff at ECE was very helpful.... Later Kirk
Kirk Myers
Old 03-12-2018, 03:42 PM   #24
MaximusD
MaximusD's Avatar
Hi Kirk, Were you able to install the ECE kit and if so what were your overall impressions? any photos to show the before and after, as I am contemplating a drop as well, I just don't wasn't to slam the truck to the ground. Any help would be much appreciated. Thanks
MaximusD is offline   Reply With Quote
Old 03-19-2018, 10:55 PM   #25
kamkam1
Project stalled out at the moment. Hopefully I can get back on it soon..
Kirk Myers
