Old 12-17-2017, 02:21 PM   #1
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
DIY4X Engine crossmember
I used this engine cradle in my 72 K/30 extended cab truck, was only in it for less than a year before I dismantled the truck. These things work great and it was a breeze to install while the motor was still in the truck. Fits all 67 to 72 4x4 frames and will also work on 2 wheel drive frames when converting to 4x4. 150.00 plus shipping
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-17-2017, 03:18 PM   #2
randy500
Re: DIY4X Engine crossmember
Can you post a picture of it and get me a box size and weight, I will email you a shipping label
randy500 is offline   Reply With Quote
Old 12-17-2017, 05:08 PM   #3
BLAZERMAN
BLAZERMAN's Avatar
Sorry I had trouble posting pics before, hopefully these work. It looks like a box would be about 25" x 11" x 7" and weigh about 25 pounds
Old 12-18-2017, 03:34 PM   #4
randy500
I assumed the crossmember was the current version where the bottom hoop is removable, i can’t use this one.
Old 12-18-2017, 10:57 PM   #5
BLAZERMAN
BLAZERMAN's Avatar
Still for sale....Just to clarify that this is the first dedign and doesnt have the drop out center. The drop out center only allows you to remove the oil pan in the truck without removing the complete crossmember, it does not allow any more clearance for other motors...other than the drop out they are the same. This first design will do the same thing but you have to support the engine from above when removing pan, remove 8 nuts and it drops right out of the way and allows more room than the second dedign.
Old 12-21-2017, 09:18 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
PM Sent
Ryan
1969 Chevy milk truck
