12-17-2017, 07:54 PM | #1 |
64 bench seat adjusting cable
Does anyone know who sells the springs and cable used for adjusting a stock bench seat? I know classic parts carries the spring on the drivers side. Can not locate a cable that runs from driver to passenger side
Posted via Mobile Device |
12-17-2017, 09:25 PM | #2 |
Re: 64 bench seat adjusting cable
It is not a cable its a solid rod. You will need to find one from a seat they are reproduced that I know of.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-17-2017, 09:36 PM | #3 |
Ok thank you. Not sure mine is the original 64 seat. The adjusting knob is black. The ones for that year I see in parts catalogs are bare metal. I found a replacement cable thru LMC truck. Do you know if there are pics on underneath a correct seat as a guide to go by?
12-18-2017, 10:39 PM | #4 |
Mine broke i tied a wire to it. Not the right way but it worked.
12-19-2017, 07:36 AM | #5 |
You may want to post a picture of the seat and how it was mounted. That may help identify the seat you have. Once we figure out the seat you have finding the parts it is missing will be easier.
Jimmy
12-19-2017, 11:16 AM | #6 |
Chevy addict
Sounds like you have a 67-72 seat. If you don't need original a wire works fine.
12-19-2017, 11:24 PM | #7 |
I trimmed the longest section from a tomato cage to replace that rod.
MusicMan70 1961 GMC Suburban |
12-21-2017, 10:18 AM | #8 |
Ingenious, would have never thought of that.....!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
