05-20-2005, 07:24 PM | #1 |
C10 Club Tennessee
Bought my Serpentine setup today!
Got my serpentin esetup today at the Pull-a-Part in Nashville. Got it all for $80. After all that I hope it works and is the right setup. Thanks to bisquick, Putter, and Gman69, for their help. The only problem I have is on the second pic is the small cut on the PS Pulley. I guess I'll have to find another one.
Thanks guys, Bryan
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
05-20-2005, 07:52 PM | #2 |
being a cheap S.O.B. i'd try dressing that pulley with some small files before I replaced it.
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page |
05-20-2005, 08:04 PM | #3 |
Good haul there Bryan. Like Rainfade said you maybe able to clean that pulley up. That setup will look real good on yours. Soooooo, is your's home yet???
05-20-2005, 08:05 PM | #4 |
Got Light Emitting Diode?
^good question
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-20-2005, 08:49 PM | #5 |
C10 Club Tennessee
Hell No!!!!!!! Went and saw it today. Nothing changed. I think the glove box got put in.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 05-20-2005 at 08:50 PM. |
05-20-2005, 08:53 PM | #6 |
gotta llllllllluuuuuuuuuuuuuvvvvvvvvvvvvv body shops
Nice serp set yellow69 |
05-20-2005, 09:15 PM | #7 |
If I am not mistaken look at a new one and it will probably be the same. For some reason I use to encounter these in collision repairs and we thought the same thing and after we bought a new one we noticed the same mark. Check and make sure though, I could be wrong about this but it's what I remember.
05-21-2005, 07:55 AM | #8 |
Keep On Truckin'
The AC compressor side looks like the one I bought but for some reason the power steering side looks different. It shouldn't matter though if it came off an 8-cylinder GM. You will probably need to drill and tap a 3/8" X 16 hole about 1/2" deep in the passenger side head for the bolt hole just under the AC compressor. Great find for $80; these setups typically bring $200 or more.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-21-2005, 08:05 AM | #9 |
there is nothing wrong with that p/s pulley!!!!!!!!
05-21-2005, 08:14 AM | #10 |
you are using original year p/s gear box?that pump will have o-ring fitting in back of it,and gear box will have flare type fitting.change out fitting in back of pump to older style if so.your changing w/p and fan both to reverse rotation also right?sure is alot of work just to have serp set-up,and i don`t think it is very beneficial,but,that`s my opinion.good luck!
05-21-2005, 08:27 AM | #11 |
C10 Club Tennessee
After seeing George's(Gman69) at Pigeon Forge I wanted one. It was just a nice clean look and gave it a newer look also. I got it off a 4.3 V6 Blazer. Bisquick said that's what he got his off of. I have no idea how to put it on, but when I don't have a truck right now I figure it out later.
05-21-2005, 09:49 PM | #12 | |
What year? |
05-22-2005, 12:18 PM | #13 |
68cst_ss490
the cut in the pulley is normal. Id run an electric fan myself. HErs a pic of your serp setup all cleaned up and mounted theu look sweet in IMHO
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
05-21-2005, 10:07 AM | #14 |
C10 Club Tennessee
Are you saying I need to go back and get the fan?
05-21-2005, 12:38 PM | #15 |
Professional Grade
yeah, the fan is a reverse rotation as well.
I am always hearing people say that you can change the fittings from the back of a power steering box. How do you do that? As far as I can tell, the fittings are moulded right into the housing of the box... Do you just pull the whole top of and put an o-ring style top on or something?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
05-21-2005, 01:00 PM | #16 | |
05-21-2005, 05:58 PM | #17 | |
05-21-2005, 06:18 PM | #18 | |
Professional Grade
Now ya tell me! LOL I've been hearing people say that I should just change the fittings out, and it has been bugging me something horrible :P This saves me a whole lotta time and money as far as installing the hoses goes, lol
05-21-2005, 07:53 PM | #19 |
cut in pully
I have seen that before it may be factory .
05-21-2005, 12:55 PM | #20 |
C10 Club Tennessee
will the fan fit okay in our shrouds? Just making sure
05-21-2005, 04:01 PM | #21 |
Bryan
Go with an electric setup like george and putter's. It'll look a lot cleaner and no worries about shroud clearance.
05-21-2005, 05:52 PM | #22 |
C10 Club Tennessee
Bill,
I'm thinking about that Nissan setup that is over on the FAQ page about the Altima and Stanza's. I'll have to see if I can find one at the pull-a-part
05-21-2005, 09:26 PM | #23 | |
05-21-2005, 09:53 PM | #24 |
A Bol In Elec. Fan Kit
I got an Old Air Products twin ele fan kit. Its a complete drop in unit that uses your stock fan shroud bolts. It even has a thermostat for the second fan. Why rig something if a properly fitting unit is made?
05-21-2005, 06:07 PM | #25 |
Both the fan and water pump are reverse rotation.
The fans usually (there are lots of different setups) will not fit our shrouds, you will need a big block fan shroud.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
