Old 11-20-2019, 12:37 PM   #901
Green Monster
Green Monster's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by ochre1971 View Post
@GreenMonster -
I picked up a dozen 2" SS carriage bolts that fit the captured nuts. Ran them through all the nuts in the top and chased any that needed it. Then cut the heads off of the nuts and ground a taper on one end of each. This is the real benefit, being able to easily access each nut while the top is in the air and being able to thread them properly.
Let me know if that explains it sufficiently, or if you were looking for anything else specific.
Thank you for taking the time to explain your setup and provide photos. I agree, the setup in your link is nice would work well with a roll bar.
If I understand this correctly, the carriage bolt is longer than the stock bolts allowing you to get your fingers in to line up the capture nuts. Do you have a photo of the carriage bolt from inside the cab with the top on?
I see you don't have the CST panels on and don't have a roll bar. The roll bar and interior CST panels on make the process of reinstalling the top more challenging.
Green Monster is offline   Reply With Quote
Old 11-22-2019, 10:06 PM   #902
ochre1971
ochre1971's Avatar
No problem. Here are a few pictures. You could certainly use longer bolts so they'd hang lower and be a little easier to install nuts on if you wanted.
The PO had 6x9's cut into the CST panels and the install was janky. I still have them, but they're in rough shape and I didn't see the need to keep putting them on and off every time I did the top.
I ended up making home-made "panels" that allowed my speaker install, cup holders for the rear seat occupants and storage compartments. It comes in and out pretty quickly with a couple of screws when I'm dealing with the top.
Functional, but I'd make a few tweaks if I did it again.
A roll bar is on my wish list.
ochre1971 is offline   Reply With Quote
Old 11-23-2019, 06:22 PM   #903
Green Monster
Ochre1971- thank you for following up with photos. I can see how your setuonis an improvement and makes reinstalling easier. Nice work and thanks for sharing.
Old 11-23-2019, 10:20 PM   #904
PDXk5
PDXk5's Avatar
I did the tailgate cable mod. It’s a great mod and super easy to do. Nothing permanently modified!
PDXk5 is offline   Reply With Quote
Old 11-24-2019, 09:24 AM   #905
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
Nice, never even thought of that mod. What is the highlighted bracket called?....anyone
72' JIMMY 454
BIG BLOCK JIMMY is offline   Reply With Quote
Old 11-24-2019, 11:52 AM   #906
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Rear top to bedside brackets. I think these were added after the 1969 model year.
As an aside, the examples painted body color seem associated with Flint assembled K5s whereas St Louis builds were painted white I assume in conjunction with the top.
Old 11-24-2019, 03:11 PM   #907
BIG BLOCK JIMMY
Thank you, interesting aside info too
72' JIMMY 454
Old 12-04-2019, 01:14 AM   #908
Hagendog
In the last two days finished preparing the top and today sprayed the Raptor liner. It’s the tintable and mixed Wimbledon White into it. The color is very similar to the parchment seats. One more coat and it’s done, probably 6 qts to finish.
Hagendog is offline   Reply With Quote
Old 12-04-2019, 10:03 PM   #909
DeadheadNM
Carpe manana
DeadheadNM's Avatar
How did the hatch turn out?
Old 12-04-2019, 10:11 PM   #910
Hagendog
So far so good. Wanted to fit everything with hardware but ran out of time. I know it fits with the hinges. We’ll see more next week; vacation time
Old 12-05-2019, 01:01 PM   #911
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by Haggar View Post
(Actually a couple days ago..) Installed new seats, so my kids have shoulder belts. These are from a 2010 Escalade.
I did the mounting a little different than others. I don't care about the removable rails for the rears, so I removed all of the brackets, which leaves you with seats with nice flat bottoms and flat metal tabs to mount to. I welded a simple metal frame, which reused the legs off the original seats (bolts into the stock mounts in the floor). I have amplifiers under the seat that I wanted clearance for. The Drivers side also only used the seat, stripped of all the factory frame, and then mounted pretty easily to my pre-existing sliders. The passenger seat kept the flip/fold base from the Cadillac, it's nice and flips up like it was meant for the Jimmy.
What sliders did you use?? What are your pre existing sliders...
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 12-10-2019, 11:27 AM   #912
Austinjay
Austinjay's Avatar
Did some raptor liner and painted the inner side panels on my 70 Blazer. I love that factory color. Napa paints did a great job matching it.
'72 K20 Ochre/white 350/350/205 4" Lift 35's
'72 GMC K10 red orange/white 400/350/205
'69 C20 Longhorn 454 TH400
'72 Blazer CST 4x4
'70 Blazer 4X4
Austinjay is offline   Reply With Quote
Old 12-10-2019, 12:52 PM   #913
raggedjim
raggedjim's Avatar
Very nice! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-10-2019, 09:53 PM   #914
mortoyz
Active Member
Went by the shop today, getting some color on 1972 factory 2wd Jimmy. Decided to go with Terrace Blue.
mortoyz is offline   Reply With Quote
Old 12-23-2019, 12:26 AM   #915
Ptjsk
Final buttoning up on the motor and started it up (sounds incredible).
Also, final assembly on with the hood. Had to adjust and move things around to finally get all lines and gaps correct.
Have to wait until spring to complete the paint on the doors and bed portion. Until then, it's ready to go!
Turned out darned good though,
Pat
Ptjsk is offline   Reply With Quote
Old 12-23-2019, 01:19 AM   #916
Hagendog
Got the top on minus the hatch and I’m happy with the way it turned out. Now have to do some adjustments since the windows aren’t really lining up with the seals. Learned a lot about fabrication and assembly on this build. Always fit everything prior to paint 🤘🏻 The hatch looks good though I’m not using the original glass; too many flaws/scratches. New one will be in this week, using the stock side hopefully Get to tint and final assembly
Old 12-23-2019, 01:34 AM   #917
Ptjsk
That is one beautiful Blazer Bud!
Did you purchase it pretty much done, or did you do a lot of the work to it?
Again....looks great!
Pat
Old 12-23-2019, 02:34 AM   #918
Spf79
Spf79's Avatar
Talking Re: What did you do to your Blazer/Jimmy today?
Pat
Looks amazing!! I'm jealous!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 12-23-2019, 02:35 AM   #919
Spf79
Spf79's Avatar
Looks great! I love the stance, what is the lift/wheels/tire combo???
Old 12-23-2019, 02:53 AM   #920
Spf79
Spf79's Avatar
I got my rear swaybar mocked in place. It was a lot harder than I thought it would be, I totally struggled, lol - it would have been so much easier with two people. I just need to take it apart and have the brackets powder coated before final assembly. Don't mind the dinosaur blanket that is on the dog's kennel. I'm still trying to figure out the nuts and acorn nuts on the link, I think it looks funny.
Old 12-23-2019, 11:19 AM   #921
simicrintz
Great looking rigs, gentlemen!!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 12-23-2019, 12:59 PM   #922
Hagendog
Pat
Took it down to bare frame and started over. I have a couple friends that know what they’re doing so 2 years and a lot of money later, I’m one lucky guy. It was a great experience learning so much about these K5’s
Old 12-23-2019, 01:01 PM   #923
Hagendog
6” lift springs, 15X12 Weld Outback’s and Toyo MT 33x12.50
Old 12-27-2019, 12:22 AM   #924
Spf79
Spf79's Avatar
Looks great! From the pics I was assuming 35's. Again, just an awesome look!!
Old 12-27-2019, 12:58 AM   #925
Ptjsk
Thanks Bud! It's coming along!
Pat
