Old 02-27-2015, 09:54 AM   #26
Popcorn W
Popcorn W's Avatar
Re: Project "Moonshiner" Bagged & Z Frame 63
I'm mocking up stuff now. I have some Schedule-80 4" pipe I'm using.
Lots of trial and error tacks, install, uninstall, repeat. I think I have the right spot now. Upper and lowers extended 2"
The camber isn't as bad as it looks here. For some reason the camera kind of extorts it. I put a laser on it and the camber is only off 2 degrees and this is at it's lowest point. I haven't measured at ride height but I think it will be real close.
My build thread:
Project Moonshiner Bagged & Z Frame 63
http://67-72chevytrucks.com/vboard/s...d.php?t=659205
"I love the smell of grinding metal"
Popcorn W is offline   Reply With Quote
Old 02-27-2015, 09:55 AM   #27
4mulaSvaliant
4mulaSvaliant's Avatar
If you are going to modify the lower, then why not the upper as well? You could correct the heavy angle on the ball joint. It'll take a bit of work to get the geometry correct, but hell, if your up for the task... Why not give her a shot?
Edited!!!!
Hahahaha Scratch that! I see you are well ahead of my thoughts here!!!! LOL
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 02-27-2015, 09:59 AM   #28
Popcorn W
Popcorn W's Avatar
Again, the camber is only 2 degrees off. Not as bad as it looks in these pics form some reason.
I ran a laser along the bottom of the frame to the bottom of the front tire and they are the same height.
If I rework the rear crossmember I think this will get me laying frame. But I don't think it's possible to lay frame with stock trailing arms, is it?
My build thread:
Old 02-27-2015, 10:01 AM   #29
Popcorn W
Popcorn W's Avatar
Edited!!!!
Yea, both are done. I don't think I took a good pic of the upper off the truck. I'll take a pic of it when I pull it back off.
My build thread:
Old 02-27-2015, 10:44 AM   #30
chevyrestoguy
chevyrestoguy's Avatar
Popcorn, you're a maniac! I haven't seen someone build a stepped a-arm in a long time. You already know this, but gusset the crap out of it, and box it where ever you can.
If you want to gain a bunch of caster, check out my caster thread, where I devised a very simple way to gain a bunch of caster for essentially no money.
http://67-72chevytrucks.com/vboard/s...d.php?t=501241
I love what you're doing, keep it up. Maximum effect, with high quality work being done on the cheap. You're talking my language!!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-27-2015, 02:43 PM   #31
Popcorn W
Popcorn W's Avatar
Thanks! Yea, low-buck is the name of the game here. I figured I'd give this a try. Worse case, it cost me welding wire, Argon and some time.
I know I may get flamed for this but I really didn't want to convert to disks either, which is required with the drop spindles. Thing is, I'm an old school old timer old fart. I was in high school when this truck was new, if that gives you an idea. I've got nothing against disks, I'll convert to dual master cylinder, but I'm very comfortable with drums.
It looks like I'll have plenty of room for some substantial gussets that can run the outer edges of the arms with no problems.
And thanks for the caster idea. I'm subscribing to that thread to save it.
My build thread:
Old 02-28-2015, 08:57 AM   #32
provelless
Using your stock trailing arms with 3' blocks should get you laying frame.
provelless is offline   Reply With Quote
Old 03-22-2015, 07:54 AM   #33
Popcorn W
Popcorn W's Avatar
upper & lowers
My build thread:
Old 05-24-2015, 09:33 AM   #34
Popcorn W
Popcorn W's Avatar
Springtime is busy farming time so work on the truck has really slowed.
It didn't look like I was going to get low enough with the stock trailing arms so I decided to Z the rear too. Now I wish I would have trimmed the step notch lower. Oh well, no biggie.
My build thread:
Old 03-20-2018, 12:29 AM   #35
Hammr
Any more to this build?
Hammr is offline   Reply With Quote
Old 03-29-2018, 02:53 PM   #36
Popcorn W
Popcorn W's Avatar
Sorry I haven't updated in a long time. Life kinda gets in the way sometimes.
Got the inside cleaned up a bit. I don't have "before" pics, but it was flaking blue paint that was painted over flaking red, if you get the idea. The headliner, and back of cab is done too. I still have to do the door panels.
My build thread:
Old 03-29-2018, 02:56 PM   #37
Popcorn W
Popcorn W's Avatar
Got the control arms all on. Re-positioned the tie rods to the bottom to correct bump steer.
My build thread:
Old 03-29-2018, 03:00 PM   #38
Popcorn W
Popcorn W's Avatar
Getting pretty close to having a "roller"
I still need to cut and u-joint the steering shaft next.
My build thread:
Old 03-29-2018, 03:03 PM   #39
Popcorn W
Popcorn W's Avatar
Weird camera angles kinda make it look like a longbed but it's a short bed.
My build thread:
Old 11-10-2018, 08:02 PM   #40
rusty76
rusty76's Avatar
Any updates on this beast?
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-13-2020, 12:51 PM   #41
Popcorn W
Popcorn W's Avatar
It sees sunlight!
My build thread:
Old 02-13-2020, 02:14 PM   #42
doobiebro
doobiebro's Avatar
looking good Popcorn!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 02-13-2020, 05:55 PM   #43
SCOTI
SCOTI's Avatar
Nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 02-13-2020, 08:26 PM   #44
60chevyjim
60chevyjim's Avatar
it looks good , I like it !!
im leaving drum brakes on mine too, im gonna pancake my front crossmember instead of dropped spindles.
60chevyjim is offline   Reply With Quote
Old 02-13-2020, 08:58 PM   #45
Popcorn W
Popcorn W's Avatar
Yea, I'm just old school I recon. I like disc brakes, but I'm different from some of the younger crowd who thinks it's required. This truck ain't gonna be a highway traveler, just an around town cruiser.
My build thread:
