05-13-2017, 12:56 PM | #1 |
Wheel Vintiques fitment
05-13-2017, 04:21 PM | #2 |
Watch out for your cornhole !
Re: Wheel Vintiques fitment
Is that the Wheel Vintiques series 62, OEM type of hubcap wheel ?
05-13-2017, 04:22 PM | #3 |
I believe it is the series 55
05-13-2017, 04:29 PM | #4 |
Series 55 is a Ford Mustang wheel.
I'm not trying to muddy up your thread with inane details. But, I have a set of the OEM hubcap Wheel Vintiques wheels sitting in my shopping cart at Summit Racing, so I'm following this closely.
05-13-2017, 04:32 PM | #5 |
Yes they are a 62.
05-15-2017, 03:21 PM | #6 |
Took that lip off with a grinder but they still won't fit. So the entire lip needs to be trimmed, or they just will not work.
I found out that I have the 2.75" brake pads (HD) which may make the drums wider and cause this. I tried a different set of drums, but it didn't help. I think the lip needs to come down more since I tried an OEM steelie and it fit fine, but putting it and the Wheel Vintique beside it there is a noticeable difference with that lip. |
05-15-2017, 05:58 PM | #7 |
Bad news huh ? There goes your nice finish on the back of the wheel I guess.
08-19-2020, 07:13 AM | #8 |
Reviving this one to see if changes have been made or if people are still having issues with fitment. I just put an order in with Wheel Vintiques for the 62 series (15x7 with a 4.24 BS).
Has anybody else had issues with this 62 series wheel? |
08-19-2020, 05:25 PM | #9 |
If you have the HD rear drums, there can be an interference issue depending on the size/back-spacing.
08-19-2020, 11:56 PM | #10 |
hmm, looks like I'll have to do a search to see what a HD rear drum measures and then measure mine.
I don't what to have to grind but if its minor I guess I'll just have to take a little of the top. |
08-20-2020, 09:38 AM | #11 |
Go to your local parts store & grab a drum for the HD app & the standard brakes. Set each in a wheel & compare.
08-20-2020, 10:56 AM | #12 |
08-20-2020, 01:07 PM | #13 |
Just keep the receipt & the parts clean/un-damaged for easy returns.
08-20-2020, 01:36 PM | #14 | |
Now if it so happens that I do have the HD drums, what all is involved to switch over to "standard drums"? Drums, backing plate and brake shoes? What did I leave out? |
08-20-2020, 03:35 PM | #15 | |
08-20-2020, 04:56 PM | #16 |
Thank you for your help. Now nothing left to do but wait for the wheels and the hub caps I got on eBay. Thank again!
08-21-2020, 11:46 AM | #17 |
Is your truck lowered? The 4 1/4 bs is more along the lines of the van wheels and tucks the wheels further into the wheel well.
08-21-2020, 04:32 PM | #18 | |
Does the stock OEM wheel have 3.75 of BS? Would 3.50" BS on the 62 series be a better fit? Last edited by Robzkombi; 08-21-2020 at 04:51 PM. |
08-21-2020, 05:15 PM | #19 | |
EDITED: On a side note, Wheel Vintiques sometimes just aren't fun to deal with. I've been trying to get technical info on their 17" 62 series. Finally was able to get a human by going to the 'place an order' extension (vs technical questions extension). I inquired about what (if any) brake upgrade 'kits' would/could work w/the 17" version of these wheels. I specifically asked about the most common big-brake upgrade kit (C5/PBR 2-piston caliper/13" rotors) like what you'd get from Baer or CPP. The answer? 'They don't know exactly'.... He said he would need to know the dimensions of my brake kit to tell me if they 'might' fit. I questioned the logic saying that since I wanted to run a 'steelie' that I kind of needed to know what would/could fit vs buying a brake kit first & hoping it would work w/their wheels. "That makes sense" was the response. I do have a C5/C6 set of calipers & a 340mm (Z51) rotor that were slated for a previous C10. I've been thinking of re-allocating the calipers & SS flex lines to use on something else w/a smaller standard 325mm rotor. Kinda' want to know if they'll fit within the wheel before commiting to purchase adapter brackets & parts.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-21-2020 at 05:31 PM. |
08-21-2020, 05:24 PM | #20 |
I called the people over at wheel vintiques to ask them a couple questions but no answer I even sent them an email and my message was blocked hmm...anyway, If I were to add that 1/4" spacer that would bring the BS to 4" which I hope will be fine. Unless of course my math is off and that's a good possibility.
08-22-2020, 02:40 AM | #21 |
Check out this thread...
https://67-72chevytrucks.com/vboard/...d.php?t=766038 I believe I went through the same thing you are going through... I had a 70 c10, but it had a 5 lug rear out of a Squarebody with the larger brake drums. Series 62’s wouldn’t fit at all... ended up swapping rear brakes for a set from a 72. Still 5 lugs but smaller/different drum mounting surface. Hardest part was finding the backing plates. Everything else I bought from NAPA. See if that helps at all...
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
08-22-2020, 02:41 PM | #22 |
Heres a list of what I have, but I'm not lowered so don't need to worry about any clearance issues with body panels. Thats why I asked if you where lowered due to the b.s. you had. My trucks are not lowered, so I tend to prefer less b.s. in general.
aftermarket 15x8's with 4" b.s 15x8 1986 rallys are also 4" b.s. 15x7 1983 rallys are 3.5" b.s. 15x6.5 1984 van rallys, 4" b.s. (I no longer have these) 15x7 6-hole chrome wheels have 4" b.s. (the chrome style like used on the 1990 454ss, do not know the source or specific year of these) These where on my '81 when I got it. Picture of those is in the topper thread if you can't picture what they look like. Last edited by Axle; 08-23-2020 at 11:10 AM. |
08-22-2020, 06:43 PM | #23 | |
08-22-2020, 07:10 PM | #24 |
I did get a chance to read that link you posted. It appears that he used a 1/4" spacer in front and the 11"x2" rear drums...one option I am considering is a rear disc swap and that would fix the rear end issue. Thank you for that link.
08-22-2020, 08:37 PM | #25 |
IF the rotor & caliper are small enough & the correct offset {it depends on what kit you use).
